Results 1 to 15 of 18
Thread: Autocom Vox & Wind
    Mar 2008
    Asheville, NC
    Autocom Vox & Wind
    I've searched and can't find a similar post- but I'm sure this is a common issue and I'm hoping someone has found a solution. I just installed an autocom and I thought it worked great until I took my first ride with a passenger. Unfortunately my passenger needs/likes to ride with her visor open much of the time. With her visor open the vox constantly gets set off, muting the music and putting amplified wind noise through the ear speakers. I have an R12RT w/an Aeroflow w/s so I'm pretty sure I've created the best case scenario for wind management. Even with vox set at least sensitive setting the issue occurs. She's wearing an Arai full-faced helmet and I've checked to make sure the microphone is adjusted appropriately with the tan side towards her mouth. If it's not possible to make this work with her face shield open I'm wondering if it's possible to rig her microphone so that it's push-to-talk instead of vox...that way she can blast her face with as much wind as she wants and I won't have to hear it! Any ideas/suggestions?
    Jay
    '08 R12RT
    Denver, CO
    Jan 2008
    El Paso, TX
    Have you installed the foam windsock over the microphone?
    jcridge
    Quote Originally Posted by 109398 View Post
    Jay,
    I have an Autocom with a full face HJC and ride with the visor up allot of the time. The mic needs to be mounted as low as possible and near as possible to the center of the lips. I have my mic tilted slightly downward. This seems to help somewhat, but if she's getting the buffeted wind off the windscreen it's going to set the VOX off. I have my VOX setting about half way and it works perfect with the shield closed and cuts out at times with it open at speeds up to 70mph after that I need to have the visor closed. Extra mic foam ( Radio Shack)on the mic will help attentuate the sound the mic hears, this should help.
    Mar 2008
    Asheville, NC
    Quote Originally Posted by ljjohns View Post
    Mine didn't come with an additional windsock- it's covered in an oval-shaped foam that's black on one side and tan on the other. The manual says tan side toward mouth, black toward the helmet chinbar. I'm going to head to radio shack per jcridge and see if I can purchase some additional foam and reposition her mic in the hopes that it will cut down on false triggers.
    Jay
    '08 R12RT
    Denver, CO
    Mar 2008
    Asheville, NC
    Called Autocom- they have a kit like you described and I was reassured that it would fix the issue as it is, apparently, a common complaint they get when customers install the system. I'll install when it arrives and update here. Thanks again for the suggestion.
    Jay
    '08 R12RT
    Denver, CO
    Pepperfool GSAddict's Avatar
    Feb 2008
    Sechelt, British Columbia
    +1 on that question
    I had to add them. A bit pricey for what you get. Should come included with the kit. Mine wore out pretty quickly so I went to the Dollar Store and fitted a $1 headphone foam to it (you even get an extra!)
    Ufda happens..........
    Rally Rat RTRandy's Avatar
    Feb 2004
    Dallas, Texas
    It's very important on the Autocom system that the mike is kept up against the lips. Not an eighth or quarter inch away, but against the lips. So much so, that sometimes the mike needs to be pushed into the open mouth to put tention the boom to keep it firm against the lips.
    It's designed this way with a sharp fall off to avoid wind noise. There's nothing unusual about riding with the visor of a full face helmet cracked or wide open. If the mike is away from the lips, it will pick up wind noise. The voice is gone after a quarter of an inch.
    Their foam wind sock might help, but it is intended for flip up helmets or 3/4 helmets.
    Depending on which Autocom you got, they make a second discrete mike which points out the back of the helmet to sense wind noise and adjust volume levels.
    The push to talk button is only going to help on bike to bike communication when you want to keep your on bike conversations private.
    Feb 2008
    Quote Originally Posted by RTRandy View Post
    I
    It makes a significant difference on full coverage helmets also. Not might, it does.
    jpelliciotta
    AutoComm Problems
    My wife and I just flew to Orange California to purchase an RT (my third). We found this one at Irv Seavers BMW. Fantastic people. I highly recommend doing business with them. We flew in from Seattle and rode back home with our new prize. We purchased an AutoComm system so we could communicate on the week-long trip back home. It was the biggest source of frustration on the entire trip. We had problems with the system from the get-go. First dialing in the VOX was a pain. Then the system would shut off/stop working. First time it was after about three hours of use, then it was after about an hour. At first I thought I got a bad 9 volt battery so we replaced it and it seemed to work fine- for about an hour. When we got home I started calling to get support and found the US Distributor (Topgear) the biggest bunch of buttheads. First phone call went to an answering machine. They never retuned my call so after 6 hours I called back and must have disturbed the technitians afternoon nap because he was rude to the point of comedy. I asked for management and this guy spoke softer was no help either. Their only solution was to "send it in we'll look at it and let you know what's wrong with it. Then we'll either fix it or replace it." I spent $300 for a system that was bad out of the box and now they want me to do without, pay for postage and accept a "repaired unit" for new. I told him I was going to return the unit and dispute the charge with Visa. The manager said that was my choice but was between me and the dealer that sold the unit. I called back to Irv Seaver to tell them of my problems and the parts manager said "how about if I send you a new one? I'll include a return shipping label and when you receive it just put the bad one in the envelope and send it back. " As I said earlier "great bunch of people and I highly recommend doing business with the folks at IRV SEAVERS BMW. The AutoComm system and their support network are not!
    Jun 2006
    Berkshires - Massachusetts
    Same problem here. Go to the dollar store and buy a stereo headset and use the foam pieces from that. 50 cents apiece!
    glennhendricks
    Stupid question
    OK, maybe a stupid question but here goes.
    I wear earplugs because of the wind/helmet noise. So how do you hear a communication system when you're wearing earplugs?
    Feb 2008
    Quote Originally Posted by glennhendricks View Post
    Huh?
    Aug 2005
    NE Ohio
    Here's how many do it including myself.
    Etymotic Research ER6i Isolator In-Ear Earphones
    Autocom In-Ear Speaker Headset Extension Lead: Coiled
    glennhendricks
    Kwell
    Grazi
    jcridge
    My Autocom system has plenty of volume to overcome road noise and ear plugs for BTB, MP3 and cell phone. The MP3 and cell would sound much better with earphones but for the most part the system works great with foam ear plugs at 70MPH. If you set up the Autocom for use with earplugs, you will never again forget to put your ear plugs in....it's loud.
