Results 1 to 12 of 12
Thread: Pine Sap on Tent
    Club President gsjay's Avatar
    Johnstown Pa.
    Pine Sap on Tent
    I camped this weekend under a bunch of Pine trees and now my tent has Pine Sap all over it.
    Anyone got an idea of how to remove the SAP?
    jason
    Jason Kaplitz
    Johnstown, Pa
    Laurel Highlands BMW Riders #294
    try spraying some Deep Woods OFF! on a spot and lightly rub the sap off. Normally takes it right off cloth but you should try this cautiously on tent material.
    cruise_carter
    try using 'Goo Gone"
    http://www.googone.com/googone.aspx
    It works on removing tree sap and is generally safe on most fabrics.
    Try it on small area 1st.
    Dale
    Registered User MOTOR31's Avatar
    Aug 2006
    Full timr RV'er, where we park is home. No fixed address or location.
    I used a very mild solution of Simple Green and water to remove pine sapo from my bike and Jeep. No scrubbing and it cleaned right up.
    DEFINITION OF A VETERAN A Veteran - whether active duty, retired, national guard or reserve - is someone who, at one point in their life, wrote a check made payable to "The United States of America", for an amount of "up to and including my life."
    Author Unknown
    Johnstown Pa.
    Quote Originally Posted by wuli959 View Post
    Works pretty good...........
    thanks,
    Jason
    might try the simple green next time.
    Jason Kaplitz
    Johnstown, Pa
    Crisco
    Crisco
    But don't camp in bear country afterwards.
    Registered User ALIENHITCHHIKER's Avatar
    Oct 2004
    Asheville, NC
    turpentine
    Steve
    Current Hottie: '00 R1100RT
    Old Flames: FY K100RT, '80 XS850 with Vetter Quicksilver, '67 Bonnie, '66 Honda 90
    darcym
    Wd 40
    I had some goo on my old tent trailer. I hadn't used it in 3 years, and it wouldn't come off with scrubbing, simple green, anything. Then I remembered parking under some pines a few years back ... and it had to be pine sap. I squirted the WD-40 on it and off it came. Make sure the tent fabric can handle it.
    Registered User burnszilla's Avatar
    May 2004
    Redwood City, CA
    Car detailers use rubbing alcohol to remove sap. YMMV.
    Stephen Burns - 2007 R1200GS
    BMW MOA Lifetime Member
    www.burnsmoto.com GS911 WIFI BMW Motorcycle Diagnostic Tool
    mrich12000
    White Naptha, works great (don't rub hard or youll go up in flames)
    aka Papa Yams jyambrovich's Avatar
    Scotts Valley, CA
    Removing tree sap
    I successfully use Murphy Oil Soap to remove tree sap from our cars and my bike (though the bike is usually not stationary enough to have a tree drop anything on it).
    Won't harm ANYTHING, except the dirt or tree sap.
    I also use it to "shampoo" the inside of my helmet, leaves a pleasant smell.
    JAY
    2000 R1100RT, Opal Blue 87,000 miles
    57,000 BMW miles in 6 years
