Results 1 to 3 of 3
Thread: Depth Gauge
    Slow & Easy
    Dec 2005
    Austin, Tx
    Depth Gauge
    GM List. I'm losing my crown bearing(28k miles on 2nd bearing) again and the bike is out of warranty. I've read thru the BMW manual on the shimming procedure. I don't own a depth gauge and need a recommendation for a not to expensive one that can do the job. I want to do a preload on the lite end of the range .002in. Can I trust one from Harbor Freight??? or Sears??
    Thanks list
    Dave Faria
    Curmudgeon nrpetersen's Avatar
    Sep 2004
    minnetonka mn
    A depth gage is easy to check. Set it / press it on a flat surface (such as a heavy glass plate, or a bench saw table etc) & see that it reads zero properly. If not, offset any readings accordingly. I'd go for the HF one.
    Retired w 2005 K1200LT, 2000 R1100RT, & 1975 R90/6
    Slow & Easy
    Dec 2005
    Austin, Tx
    Thank you NRPetersen.
