Results 1 to 9 of 9
Thread: Hidden Dangers in Wyoming everyone should know
    Registered User redclfco's Avatar
    The last of Chief Joseph Nez Perc?® tribe still exist in Wyoming, and unsuspecting solo riders who choose to ride at night or the wee early morning hours should take note; this band of outlaws will on occasion take down unsuspecting airheads and small Kawasaki motorcycles on the vast empty Wyoming roads. Those people are usually found expired, with the AGATT still in place; this is a real threat, and our BMWMOA group should be aware of this hazard. The tribe usually tortures the victim by force feeding them copious quantity of Idaho spuds soaked in clarified butter for days on end, then setting them outside on a cold night where upon their arteries harden-on the spot; a horrible way to die.
    It was discovered years ago that Wyoming men have an extremely high libido, thus causing many random acts of "love" to occur in the small frontier towns in Wyoming. Since that discovery ion 1876, all restaurants in the state of Wyoming add salt peter to their food in a way to combat this higher state of libido. As our group gets ready to come to Wyoming, it should be known that upon reaching any food establishment, an unsuspecting tourist should check the menu for the fine print showing "SPA additives" OR just ask the waitress to point out the items on the menu that are SPA free. This is currently in the Wyoming legislature as a house bill to ban this practice, the bill was sponsored by the league of women voters in the state. Obviously, this is a problem for many women who now have to compete for their man's affection with his love for football and other mindless activities! Watch out members of the BMWMOA for this hidden hazard!
    It is not widely known that the jackelope (i-shephan-im-antemeridian) was the actual cause of death of Steve Irwin in Australia . The i-shephan-im-antemeridian is also a native of Australia, and because it is sooo embarrassing that Steve died by the horn of this creature after imbibing in too many Fosters that the story about the stingray was published in an attempt to save poor Bindi Irwin the embarrassment of how her father died. Wyoming also has the native i-shephan-im-antemeridian living in their land. Usually, the jackelope will not approach a car or any vehicle with four wheels, but has been known to approach in large numbers unsuspecting motorcycles; DO NOT ATTEMT TO TOUCH THEM as did the late great Steve Irwin for they have the ability to use their short stubby horns to gore you right through the toughest ATGATT you may be wearing! The forward thrust of these animals can be compared to the forward thrust of a R1200GS in fist gear at 4000RPM! Poor Bindi will never know....
    The last hazard has to do with mini lighting bolts in the dry air of Wyoming. This little known hazard has caused many a person to, at minimum loose consciousness, and at worst die on the spot. The cause? Jewelry! If you have tongue rings, nose rings earrings, belly rings OR metal studs attached in the nether regions, it's best to remove them before coming to Wyoming. The cause of these deadly mini lightning bolts were described in the Boston Scientific article published in 1988, issue 14, page 63 that documented when the dry Wyoming air comes into contact with perspiration (such as the sweat caused by all our ATGATT) the static electricity volts and Amps increase ten fold from what normally would be harmless electricity, and of course, seeks ground through the most likely spot' your jewelry! Many a man or lady have been found dead with burns and in a state of cardiac arrest due to this phenomenon found the dry, high altitude air of Wyoming. Watch out for this hazard brothers and sisters of Wyoming!
    Hope all this helps in making your trip this month safe and sound!
    Red
    Rollin' by the River R1100rtp's Avatar
    St. Paul, MN
    Quote Originally Posted by redclfco View Post
    We Really should have asked you to do a Storytelling seminar......
    Ride Hard, go far, and keep smilin...
    Karol Patzer, Ambassador, Director BMW MOA Foundation
    2008/2014 BMW MOA Rally Chair
    Amma Holly's Avatar
    Ancaster, ON
    It's a myth
    [B]
    Red
    Saltpetre was used in food in Iceland. My great-great grandfather had 23 children. Obviously the saltpetre had no effect. 6 months of darkness on the other hand...
    Holly
    Apr 2007
    Penn Hills, PA
    Red
    So, standing in the middle of a stream waving a stick is ok as long as I remove my nipple ring? On a lighter note, never attempt a roll cast w/o a shirt on and nipple ring in place. During the forward portion of the cast, when the line is loaded and the fly is moving past the fisherman with considerable speed, it has been known to hook the ring, in which case the fisherman hurls himself to the awaiting trout. No kiddin', they got pictures of me.
    Ol salt
    Saltpeter in Bootcamp
    Saltpetre does work. The doses I GOT IN BOOTCAMP 50 YEARS AGO IS FINALLY STARTING TO WORK!!
    Registered User beemerron's Avatar
    Rexhall Aerbus in PNW
    Quote Originally Posted by rik View Post
    Nipple ring w/o a shirt on sounds more like trolling than fly fishing.
    Ron R
    #39306
    Registered User dancogan's Avatar
    Aug 2004
    SE Michigan
    Quote Originally Posted by olsalt View Post
    Dan
    Apr 2007
    Penn Hills, PA
    Quote Originally Posted by beemerron View Post
    Actually, you are correct. Trolling, or the hunting and harvesting of trolls, was one of the grand sports of the Bavarian kings in the seventh and eighth centuries. An accused witch, referred to as a worm, would be lowered over the side of a bridge on a long pole affixed to a ring embedded in the breast area. As this sport was only practiced at night, and it was very dark over the side of bridges, a white duck was placed at the end of the pole to act as a signalling device. As the troll came out to take the worm, the ducks head would begin to move up and down, giving to the term bobber. Anyway, when the troll took the worm it would be snagged by long hooks, or gaffs, and hauled up and onto the bridge and subdued with Willhelms, our present day billy clubs. So you are correct, it has absolutley nothing to do with flyfishing. Today, trolling is only practiced in Chicago.
    Payson, AZ
    Only in Chicago?
    Trolling on the Michigan Street Bridge on the 4th of July, I'm guessing. Damn, I'm going to miss it again this year!
