Results 1 to 14 of 14
Thread: PIAA light brackets
    PIAA light brackets
    Recently bought PIAA 1100's,but having trouble finding brackets to buy for my R 1150RT
    Any help in locating some? Any help on sources and installation gratefully accepted . Thanks
    Registered User clowry's Avatar
    Oakville, ON
    Give Cyclegadgets.com a try. They're pretty good for that kind of thing.
    Cheryl
    grossjohann
    Which R 1150? R, RS, RT...
    brackets
    Should have mentiones RT.
    Also looking for others than Cycle Gadgets
    Feb 2006
    Long gone
    I don't know if he has any stock left but Pat made excellent brackets. Try http://www.empdesigns.com/
    Ride Well
    1024JLC
    PIAA mounting on R1150RT
    I just mounted my PIAA lights on my 04 R1150RT this past weekend. I used Easy Mount Bracket http://www.ezymount.com/kits/ezymount_r1150rt.htm . Worked like a charm. Took about 2-hours (including the removing and replacing of the tupperware). I beleive that I bought the kit from CycleGadget.com. I also wired in an AutoSwitch so I can turn the PIAA's on and off with the turn signal cancel switch. Makes for a clean install and prevents leaving the lights on when I get off the bike.
    bored, bored ... dlowry's Avatar
    Dec 2005
    Snow Country, ON, Canada
    I have a set of the PIAA 1100X with the Ezymount for an 05 R1200RT. A few comments - the lamps vibrate, a lot! The bracket is made out of a weak metal, and no reinforcement at the bend, hence the vibration. One of the brackets broke going over a railroad crossing. Cyclegadgets are warrantying the brackets so I'll get them replaced, then take them to a local fabricator and have something stronger made including a cross member to increase the rigidity. The do say you should only use them on ESA equipped bike now, they didn't when I got them. In the meantime, I have moved them down to the fork using the fender bolt on the side of the fork.
    Sorry for the crappy camera phone images, but you'll get the idea...
    Dave...
    15 R1200 RT
    83 XN85 D Turbo
    buckeyeclark
    I know it is not for everyone; however, I used a simple piece of 1/4" aluminum bar stock bent it to the shape I wanted and clamped it to the slider. Rock solid and looks pretty good. I might have $10 in both side together. Just a thought.....
    Registered User ekroth's Avatar
    Jun 2007
    Delmar, NY
    Hey Clark,
    How 'bout a detailed pic or two? Sounds like a good mount...
    Eric
    Hear that ticking sound? jnerges's Avatar
    Jun 2006
    Columbia, SC
    I used PIAA's bracket for the 510's on a GS. Very easy to install but I am not sure if they make a set for the RT. I got them at Cycle Gadgets. Pretty good customer service.
    Good luck.
    Quote Originally Posted by dextermaya View Post
    buckeyeclark
    Quote Originally Posted by ekroth View Post
    Hey Clark,
    Eric
    I will try and get a couple posted today. Did I mention the aluminum bar stock fog light mounts I made for under the jugs? I will get a pic of that situation also...
    buckeyeclark
    I am attempting to upload pics; however, when I click on "upload" nothing happens...what gives?????????
    buckeyeclark
    Here you go..........
    buckeyeclark
    Another
