Results 1 to 5 of 5
Thread: Wierd ABS fault
    On the Road spikethebike's Avatar
    Apr 2004
    Portland, OR
    Wierd ABS fault
    I have been getting ABS faults when I hit bumps with my K12RS.
    When I stop and switch the ignition off then on again, it clears.
    This caused me a bit of excitment at one point today as I got a little air at the same time I needed to scrub off a bit of speed- the front locked and started to go sideways, butt I caught it before it got too interesting.
    Could this be caused by the sensor gap being a bit off?
    Thanks a lot for any suggestions!
    Spike
    Focused kbasa's Avatar
    I'd try that, Spike, but I'd look and make sure the sensor is mounted securely too.
    Dave Swider
    Marin County, CA
    Apr 2004
    Portland, OR
    Righto, I'll check everything in the general area. I know this is not supposed to happen as I have hammered my previous K12 over Mattole road at injudicious speeds without a problem!
    On the Road LICK MY BRICK's Avatar
    NEW YORK CITY
    Talking
    A Little air?
    Things are different in PDX, especially if you're Spike.
    Dave Swider
    Marin County, CA
