Results 1 to 7 of 7
Thread: Bug Catching New Rider
    Loading the Bike
    May 2004
    Watertown, New York
    Cool Bug Catching New Rider
    I've just purchased my first BMW a 85 K100RT. I really love the ride but the previous owner "sporterized" the windshield so it's practically useless. My helmet is like a huge bug collector. I've been searching for options but am have trouble finding a replacement windshield. What works and where do I get it , O great wizards of experience? Do I really have to spend $250?
    Item two is the speedometer is dead and so is the automatic turn signal cancel. Should I just buy a new cable and try that first? Is there a way to test if an electrical signal is comming from the rear pickup assembly?
    I've ordered the Haynes and Chilton manuals for help but think this is a far better source of collective knowlege.
    JF
    PS, I can't wait for my first ralley
    Former Club President DonHamblin's Avatar
    Lee's Summit, MO
    85 K100RT
    JF,
    - Item one: Parabellum
    - Item two: Read those manuals before buying a cable.
    Enjoy the "hot one" - I loved mine!
    Don
    Focused kbasa's Avatar
    Dead speedo? Common on K bikes.
    You probably don't need a cable, you need to do some work on the cluster itself.
    Go about halfway down this page. There's tons of good info. Don Eilenberger had a bike just like yours and knows those things inside and out.
    Dave Swider
    Marin County, CA
    Fixin' ta ride tinboatcapt's Avatar
    Mar 2004
    Lakeville MN
    Speedo
    Before takng anything apart, I found on my 86 K100RT I can "Cure" an intermittant Speedo by "Wiggling" wires in two places: First look under the right hand side cover and find the connector that comes from the pick up on the rear drive unit. I finally got smart enough to put a wrap of electrical tape around it.
    The second place is the connector to the "Brain box" It tends to need to be pushed back into place occasionally. Then the Speedo works agin. Worst case here is, if it gets too loose, the bike won't start. I haven't figured out an easy way to anchor it in place. The wire clip has worn to the point of uselessness.
    Do look at some of the other posts on this subject. I'm not expert on the "K". I have only owned this one since August.
    Jim
    On the Road 110066's Avatar
    Jan 2004
    Milwaukee WI
    Speedo
    #1 buy a manual - the previous comment has to do with the fact there is no "cable" - and do not look for it on the front wheel
    #2 the sensor for the speedo is on the top the the final drive by the rear wheel - they get dirty and then the speedo doesnt work
    start there
    Jan 2004
    Milwaukee WI
    additional clarity
    more info - I re read my post and left out the "what to do" part:
    clean the sensor off
    Mar 2004
    Lakeville MN
    Brian is correct...
    ..."Cable" was a poor choice of wording. The connection is electrical.
    Jim
