Results 1 to 4 of 4
Thread: Can K75 handle two heated jackets?
    maine
    Was looking at the Warm and Safe website and the men's liner uses 100 watts and the women's 90 watts. Will my 91 K75 RT be able to handle it? The only additional access. is a GPS. Oh, and the stock heated grips. Thanks for your input.
    Mark from Maine
    Braintree, MA
    Quote Originally Posted by 42016 View Post
    Mark from Maine
    Hey Mark, the later K75 bikes had a 700 watt alternator (plenty for all your heated gear), earlier ones are 460 watts.
    You can see the alternator on the right side of my '95 K75 and it has a 50 on it, meaning 50 amps. (50 amps x 14 volts equals 700 watts) I don't know if the 460 watt alternator is marked like that or not. Expect to see a number around 33.
    This bike is new to me and I haven't dug too deeply into it, but I'd also expect to see a 50 amp main fuse in the fuse box. If your main fuse is around 30 amps, you'll be on the borderline to support one heated vest, but not two.
    If you go with the heated gear or other high power add-ons like lights, it's important to monitor your battery voltage to make sure it keeps charging, otherwise it's easy to drain the battery. The battery is 12.6 - 12.8 volts at full charge. If the voltage stays above that, you're in good shape. Below that for long enough -- you'll have to get off and push.
    Check out this thread: Alternator conversion
    Salty Fog Rally 2007, 2009, 2011, 2012, 2014 AND LOOKING FORWARD TO 2015!
    -Tom (KA1TOX)
    mrich12000
    Thumbs up
    Thanks that was a nice article from the past. My bike has 2 55 watt hologen deer fogs,heated grips, the batt volts stays @12.6-13.0.I have an outlet plug under the left side cover and it runs the GPS,the 200 watt a/c adapter (for the tv,dvd,shortwave(alnico sidebander) I liked that don had found all the extra parts for the upgrade, to will be scanning Ebay for the higher amp alt. Thanks and good luck..Michael.
    maine
    Thanks for the prompt replies. So, let's add this up. Two heated jackets @ $160 or so each. Two heat controllers at $60 each. Used alternater @ $175. Total of $615 to stay warm and cozy. Maybe i'll buy my girlfriend a nice turtleneck instead.
    Mark from Maine
