Results 1 to 15 of 18
Thread: Oxygen vs Nitrogen
    Rally Rat motofranz's Avatar
    Apr 2004
    Cincinnati.Ohio
    Oxygen vs Nitrogen
    What are the advantages of Nitrogen vs Oxygen in your tires?
    Has anyone tryed Nitrogen ?
    I heard it's not worth the price
    (about 5 dollars per tire) ,but if you can get Nitrogen free of charge ..take it.
    West Salem, OH
    I don't have a handy supply of Nitrogen laying around when I check my tire pressure, and it would be a pain to locate a source when touring.
    I will just have to suffer with good old air, it has Nitrogen in it. If my memory serves me correctly, it is around 75 percent anyway. It just aint worth the trouble and the cost to up the percentage that much.
    Gale Smith
    2009 Versys
    1999 R1100RT
    WC Indiana
    Nitrogen isn't suppose to increase in pressure when heated or vise versa like air.
    Tire shops could use an air separator to get the moisture out of the air before it is installed in a tire. Then severe ambient temperature changes along with road temperature wouldn't require hot pressure checks to increase tire life and traction. If, however; the tire pressure kept in the tire is in excess of the motorcycle and tire manufacturers guidelines rendering the tire harder than hammered hell, nitrogen would have no economic or handling benefit.
    JON
    1150GS a/k/a The Impatient Virgin
    Focused kbasa's Avatar
    First time you have to add air to your tires, you $5 are gone.
    Regular air is 78% Nitrogen, by the way.
    Dave Swider
    Marin County, CA
    Registered User widebmw's Avatar
    Reno, NV
    I think you mean " Air " not Oxygen. I hope.
    Oxygen is a fast buring gas and can be Exlosive.
    USERNAME
    i think if you spend a little time noodling boyle's law and your knowledge of partial pressures from second grade physics, youll find out why they only charge $5. if they charged more, youd hunt em down for a refund when you found out how useful it really was.
    What's that noise...? basketcase's Avatar
    Alabama
    While we are on the subject (air) ...
    I decided this season to go with a synthetic summer air in my tires.
    I don't know how it will impact thread life, but the idea of less inertial drag inside the tire and rim leads me to think it will positively impact fuel consumption.
    IMHO, we should take advantage of any opportunity to conserve on the use of this overpriced fuel we are pumping lately ...
    '98 BMW Z3 Roadster, '00 R1100RT
    If you insist on exercising a right to burn our flag, first be so kind as to wrap yourself in it and then douse yourself with gasoline just before you strike the match.
    West Salem, OH
    Oxygen is an accelerant, it is not flammable, it will cause things to burn much faster.
    Gale Smith
    2009 Versys
    1999 R1100RT
    Apr 2004
    Cincinnati.Ohio
    AIR (compressed AIR )
    Not OxYgeN ....Air !
    Im going to fill my tires with helium and coast a lot .
    I think Tire Discounters is starting this nitrogen thing as a sales gimmick.
    El Dookey loves to ride. 99007's Avatar
    Aug 2003
    Ada, MI (outside Grand Rapids)
    Personally
    My tyres are filled with gel. The first time I misunderstood and put raspberry jelly in - what a delicious mess. Scooped all that out and went with the gel - it ran about $850 per tyre, but what the hell....
    ps - hey Lorazepam - is that real German or Sears German you are posting?
    Don't winterize; Rounderize!
    www.yearroundriders.com
    Motoring Malcontent ScottM's Avatar
    Feb 2004
    Dallas, TX
    Re: While we are on the subject (air) ...
    Ah, but is it enviromentally friendly?
    2002 R1150R (Black)
    On the Road 82436's Avatar
    Oct 2003
    Skyland, North Carolina
    Question German Air
    Wouldn't imported air from Germany work better in our BMW tires? I'm sure our friendly BMW shops would import this item if there is sufficient demand.
    rocketman
    Re: German Air
    I buy mine direct from the factory, along with my OEM valve stems, thereby cutting out the middle man.
    It's also important to change the air on a regular basis, I do it with every oil change.
    RM
    West Salem, OH
    Hey Cliffy
    Ich benutze Babel Fisch??bersetzer, bin, der oder die reale Sache verwelkt?
    Gale Smith
    2009 Versys
    1999 R1100RT
    Alabama
    Scott asked,
    "Is it environmentally friendly?"
    Why of course it is, provided it remains confined within the tire.
    But if escapes that secure environment, who knows?
    It might become Jurassic in nature ... sez so right there on the can.
