Results 1 to 5 of 5
Thread: R27 Carb Problem
    HOLLERDF
    R27 Carb Problem
    Just Had Carb Cleaned And A New Set Of Gaskets Installed. Runs Great Until It Gets Warm Then Runs Real Fast At Idle For 20, 30 Seconds Or Longer. Any Thoughts On This?
    Darrel
    Administrator 20774's Avatar
    There is another forum for vintage bikes, if this is really about an R27 single cylinder BMW...this might be best answered there.
    But, in general, all carbs should be adjusted when they are warm, after a 15-20 minute ride.
    What type of R27 carb? Is the carb number 1/26/xx where xx is 68, 79, 83, or 93? The internal settings are mostly the same except the main jet on the 83 is a little smaller, the main jet on the 93 is a little bigger, and the needle clip position on the 68 is the 3rd position. The idle mixture setting should be two turns out from lightly seated. After the warm up ride, you'll need to adjust the mixture for best idle. You might also need to adjust the idle speed RPM setting.
    James.A
    My thoughts are this; Your slide is sticking, or your return spring is weak, or your carb is a piece of ****, or any combination of the three. Right now, I am mocking up a 1/26/114 Bing from an R50/5 to be fitted to my R27. The original carb is the most terrible device I've ever seen. If you want to know the whole story, send me a PM or call 1-309-444-8559.
    johnpeter
    Did you adjust the valves on the tight side?
    If so, loosen them up.
    The above might be true if the slide is not sticking and the cable has play at rest.
    Oct 2003
    Moved to the vintage forum
    You may get a better response here.
    I don't know much about the singles, but if this were a twin, it would sound like a sticking centrifugal advance unit, that needs cleaning and lubricating.
    http://darryl.crafty-fox.com
