Results 1 to 11 of 11
Thread: New to me 2003 F650CS
    jimcameron
    Wow! I just took delivery of a "new to me" Scarver. Neat bike. Getting to the battery to hook up my pigtails seems to be a bit of a pia, any easy way?
    No centerstand, no accessory socket. I quess it is all about "aftermarket" income. Any suggestions on those two items?
    Last heckle. It came with a Riders Manuel, but no maintenance schedule/record book. I can't imagine it didn't have one when new, but then again, it doesn't have the two basics above.
    Anyway, looking forward to enjoying my 7th BMW in 26 years of BMW ownership.
    If any guru's are in the Annapolis area, I am a lunch buying pupil.
    jkc
    Rally Rat PAULBACH's Avatar
    Dec 2005
    The battery is a PITA to get to. But perhaps that is a blessing since the scarver was not built to add electrical accessories. I added some and even underway it was a struggle to maintain 12 volts on the ammeter. I added the digital ammeter.
    Best accessory would be a top case. GIVI makes one that is perfect for the 650CS.
    Real good news - I used to get near 70 mpg if I eschewed performance awards.
    jimcameron
    thanks Paul
    Thanks, Paul
    I just want to be able to keep the trickle charger on the bike when appropriate. I might also like to plug in my vest in the "brisk" months. Other than that, no electronics for me. I have a bike to get lost and be unable to get ahold of. If I dont know where I am, all the better. I seem to be able to find my way home sooner or later.
    jkc
    tomneville
    Maintenance Manual
    Quote Originally Posted by jimcameron View Post
    jkc
    I have a 2005 F 650 CS and can copy parts of maitenance manual you are interested in and PDF to you..
    tomneville
    Maintenance Manual
    I have 2005 F 650 CS and can PDF you parts you are interested in..
    jimcameron
    Thanks!
    Quote Originally Posted by tomneville View Post
    Thanks very much for the kind offer. I did secure a copy online. Again, thanks.
    Lifetime Member Ridealot's Avatar
    Aug 2004
    Salem Or.
    Hi Jim,
    There is a nice clean option for your pigtail to the battery. I'm guessing that on your bike just above the ignition key that the piece with the 4way flashers looks like this
    If you go to the BMW store you can order part #71 60 7 664 866. It comes with a new dash piece and the needed wiring harness to connect to your bike. After you install it your bike will look like this.
    As for the centerstand there are a couple of options. Off of the top of my head I can remember 2 companies that make a centerstand for the CS. The one I have is a SW-Motech centerstand. Hepcko-Becker also makes a centerstand. Here is a couple of pic's of my SW-Motech. It has been on the bike for a few years and about 30k miles so it doesn't look new anymore.
    It makes it much easier to do things like this. Look Ma, no wheels
    Tom
    Salem Or.
    '93 K1100LT w/Bushtec
    '09 F650GS '15 Ducati Multistrada
    Aug 2004
    Salem Or.
    Quote Originally Posted by PAULBACH View Post
    Hi Paul,
    You mentioned back when you had your CS that you had trouble with the charging system. I still say that your bikes charging system was not working correctly. The CS has a 400 watt alternator. That is plenty to run extra accessories. Heck my K1100LT only has the 400 watt alt. and I have accessories out the wazhoo on it. Even running, high beam, heated grips, and an electric jacket on my CS have never caused a problem. The only thing that would draw the battery down is if I where to run everything while idling around town. The charging system seems to start making full power with the RPM's kept above 3500. I usually ride around town at 4000 so I am always in the green as far as charging is concerned.
    I am thinking about riding my CS back to Gillette this summer instead of taking the K1100LT. The K bike gets 40-45 mpg and the CS gets 65-70 mpg. With the price of gas that is enough difference to leave the land yacht at home and take the thumper.
    Tom
    Salem Or.
    beemergrl
    Bringing CS to Rally
    I am bringing my CS to the rally. I have added softbags to it, a bestrest cargo rack and I am in the middle of addiing highway pegs. I am still researching the pegs and looking for pics of the best way to do it. 65 MPG is the way to go. I just hope we don't have many windy days, so it will make for a great trip.
    Registered User lionlady's Avatar
    Apr 2006
    Forest, VA
    You don't need no stinkin centerstand...
    I had an '03 Scarver. LOVED IT!! - put 8K miles on it (crashed it, repaired it, rode it some more). At first I was puzzled by the lack of centerstand, until I realized that it didn't NEED one. There's no chain to oil, which is the main reason for one on a smaller bike.
    A centerstand just adds weight, and is an extra expense. So, before you decide you MUST have a centerstand, just ride it and keep it and figure out if there are any situations that a centerstand is a must have on the bike.
    P
    Courage in women is often mistaken for insanity.
    R1150R Rockster, Limited Edition!
    Dec 2005
    Quote Originally Posted by Ridealot View Post
    Hi Paul,
    But to get 70mpg you have to keep within speed limits or less.
    The CS failed me on a couple of occasions. Once the battery failed - one of the cells just died - never had that happen before on any battery either two wheels or a cage. The real coup de gras was having to coast down hill to a house where I saw a motorcycle parked.
    I could not start my machine and the owner of the house and motorcycle came out and gave me a jump start off his motorcycle - a Harley Davidson. Have always had a warm spot in my heart for Harley owners after that.
    So I traded it in on a GS. I loved that machine but the love was unrequited.
