Results 1 to 6 of 6
Thread: brass vs copper washer for oil tank
    I bought a oil filter kit from the local bmw dealer. It came with 4 different washers.
    Forgetting about the small one...as far as I can tell, the bigger brass washer is for the engine oil drain plug.
    The remaining 2, one brass and one copper seems to be of equal size. I guess one of them is to be used for the oil tank drain plug. Is there a difference between the two types of washers? What if I used brass instead of copper?
    (sorry, but I may have my brass and copper wrong... what I'm calling brass is gold-looking washer, copper is silver looking washer... as seen here: http://www.ascycles.com/detail.aspx?ID=2685)
    Thanks!
    100,000+ miler 32232's Avatar
    Southwestern Ontario
    As far as crush washers go, brass is a sort of gold colour, copper a reddish-gold, silver is aluminum.
    Dave
    Ok, I found out the answer from the dealer...
    if anyone cares, the silver looking washer is not to be used.
    Jul 2007
    THE BIG SKY
    Okay, as the owner of a new F650 with 50 miles on it I'd appreciate knowing what the others are for.
    Kevin Huddy
    Tm Pterodactyl MT Outpost
    Quote Originally Posted by huddyk View Post
    If you take a look at this pic: http://www.ascycles.com/detail.aspx?ID=2685
    starting with the big washer, then going clockwise
    big gold washer - for the engine drain plug
    http://faq.f650.com/GSFAQs/Photos/En...lDrainPlug.jpg
    small gold washer - for drain plug on the water pump (for coolant change)
    http://faq.f650.com/GSFAQs/Photos/Wa...aterPumpGS.jpg
    (look at part #1)
    medium gold washer - for the oil tank drain plug
    http://faq.f650.com/GSFAQs/Photos/En...kDrainPlug.jpg
    silver washer - sitting in my spare parts bin
    HTH
    Jul 2007
    THE BIG SKY
    Kevin Huddy
