Results 1 to 3 of 3
Thread: K1200LT Front Link shock
    Timbis
    Has anyone had any trouble with this shock? I have an 03 with 3k miles and this shock is leaking badly. I'm going to take it to the local dealer but wondered if others have discoverd this problem.
    Blocking the slow lane
    Edwardsville, IL
    Are you sure its the shock and not the steering damper losing oil? The damper is more famous for failing than the shock absorbers.
    Jon Diaz
    BMW K75/K12GT
    BMWMOA Ambassador
    Timbis
    I haven't taken anything off, figured the dealer should do that but the damper looks dry and clean while the shock it's self is oil soaked and is dripping with the majority of the oil located on the main body. Thanks for the suggestion.
