Page 2 of 4 FirstFirst 1 2 3 4 LastLast
Results 16 to 30 of 59
Thread: What's in Your Toolkit?
  1. #16
    Spring Lake NJ, USA
    Done. Still open so feel free to add to it. Some photos of your toolkits would be handy. Gotta take some of mine..
  2. #17
    Mar 2004
    Alexandria, VA
    Small kit.
    Full kit
    Link to full list!
    Jim
  3. #18
    franze
    There's a lot of good stuff here!
  4. #19
    CO_G30
    what I carry
  5. #20
    Grocery Getter TGA57589's Avatar
    Apr 2006
    Washington, Utah
    I added a half of a stick of Pig Putty. There are a few different manufacturers of this stuff but it does the trick. I wouldn't be afraid to use this stuff to put my handlebars back together if I had to use it to just get home after some major breakage. I like JB weld if you have time for it to set-up but PIG PUTTY is what I keep in the tool kit and besides, they use the same stuff at work that I use for my use too so you can't beat it. If you need to know more specifics on what this stuff is send me a private message and I'll send you what's on the tube.
  6. #21
    motorcycle cowboy Tennessean's Avatar
    Oct 2005
    East Tennessee
    hmmm....I either have way more confidence in my bike or I am sadly unprepared. A GS 911 is on the way though.
    2013 Goldwing
  7. #22
    Jim..Weight?
    Quote Originally Posted by JimVonBaden1 View Post
    Small kit.
    Full kit
    Link to full list!
    Jim
    You probably have mentioned it..but what does the 'big' kit weigh? Counting pounds off road...thanks.
    Phil
    "In Wallowas"
    2007 R1200GS Adventure
  8. #23
    Not available in stores.. PAGoldsby's Avatar
    May 2007
    Kansas
    I always carry a Sharpie felt-tip pen and some 3x5 note cards. I wrap a few feet of duct tape around the barrel of the Sharpie. I also carry some "field expedient" baling wire - cut-up pieces of wire coat hangers. My first aid kit has about a dozen pairs of rubber gloves, which can be handy when working on the motorcycle. There's a tiny sewing kit, too, although I doubt the needles are up to the task of taking on a Aerostich or elkskin leather gloves. I've also got a small fire extinguisher.
    Great thread!
    I can't believe how incredulous I am.
  9. #24
    OntarioST3
    Wadsworth Ratchet Kit
    http://www.amazon.com/Wadsworth-Mini...7692159&sr=8-1
    Has anyone used this mini ratchet and if so is it woth the money?
  10. #25
    Urbana, IL
    Quote Originally Posted by OntarioST3 View Post
    I have one version of that kit (no torx). It is very well made and works well. However with the new bikes going to torx, I don't carry it anymore. You will be better off (less expensive too) by going to Home Depot and getting their mini ratchet ($15) and buying bits to suit the fasteners you need.
    My other bike is a BMW.
  11. #26
    Apr 2006
    Washington, Utah
    I took a roll of duct tape smashed it flat so it takes up less space and I also have a tube of PIG putty. I'm not sure if there are many who know what this stuff is so I'll explain, the company I work for is industrial and we use this stuff to patch holes in steel, pipes for dry products or for that matter anything that is worn of has a hole in it. It is along the lines of JB weld but it as it is a 2-part putty that you work together but it is grindable and is able to be sanded as well. The fact is this stuff would fill in a hole in your crank case fuel tank or most any material if you are able to make the surface dry. This is one of those repair items that you can fix something to just get home or to repair something you just can buy anymore.
  12. #27
    Packs in 10 x 6 x 4 Cordura Bag - moves bike to bike
    1/4 DRIVE ITEMS:
    Sockets (mm) 13, 10, 9, 8, 7, 6, 5
    Allen Wrench Sockets (mm) 8, 6, 5, plus Torx T25, T30
    Ratchet
    Drive Handle
    3 and 6 Extension
    3/8 DRIVE ITEMS:
    Sockets 19, 17, 15, 14, 13, 12, 11, 10 set, plus 13 deep and 24
    Allen Sockets (mm) 8, 6, 5, 4, plus Torx T40 and T45
    Ratchet
    Slide Handle
    Universal Joint
    3 Wobble Extension and 6 Extension
    3/8" to 1/2" adaptor
    12mm allen socket for Paralever
    22mm allen tool for R1200/K1200 front axles
    WRENCHES:
    Stubby set (mm) 19, 18, 17, 16, 15, 14, 13, 12, 11, 10, 9, 8
    Ratcheting Box End Stubby (mm) 13 and 10
    Ignition Wrenches 90 degree open end (mm) 11, 10
    Motolight Lens Ring pin wrench
    Ball End Long Allen Wrenches
    Folding Torx Drivers T30, T27, T25, T20, T15, T10
    PLIERS:
    Slip Joint
    7 and 5 Slim Nose Vice Grip
    Ignition Pliers
    Combination (fold over) Needle Nose / Diagonal Cutter
    OTHER:
    Feeler Gauge Set
    Magnetic Pickup / Screw Holding Screw Starter
    Small Flat File
    7 Tapered Punch
    Hook Scribe
    Inductive Spark Tester
    Flexible Light
    Combination Screwdriver 2 each Phillips and Straight Tips
    Compact VOM with Slide-On Alligator Clips for the Leads
    Shock Wrench Handle used as Extension Handle for ? Ratchet or Slide Handle
    Then, also:
    Original BMW took kit for bike - stays in each bike
    And
    12v Cycle Pump
    Tire Gauge
    Compact Jumper Cables
    Tire tools - plugs and patches
    Tire Irons
    Large C clamp for a bead breaker
  13. #28
    Registered User thompsonr's Avatar
    Nov 2007
    Topeka Kansas
    Tool kit
    Ok this is whats in my tool kit well the most important things anyway The Anonymous book ,cell phone to call numbers in book, Visa card to pay for repairs and flashing battery powered red light to keep from getting run over till help arrives.
    Oh yes I have the screw drivers, complete wrench set, ect. ect. but those are more for show than work. I know my limitations.
    R and R
  14. #29
    Quote Originally Posted by thompsonr View Post
    Well - cell phones and credit cards have "limitations" too At least mine do!
  15. #30
    EXPATRIATED
    1/4 DRIVE ITEMS:
    Ratchet
    Drive Handle
    3 and 6 Extension
    3/8 DRIVE ITEMS:
    Ratchet
    Slide Handle
    Universal Joint
    WRENCHES:
    PLIERS:
    Slip Joint
    Ignition Pliers
    OTHER:
    Feeler Gauge Set
    Small Flat File
    7 Tapered Punch
    Hook Scribe
    Flexible Light
    Then, also:
    And
    12v Cycle Pump
    Tire Gauge
    Tire Irons
    Wow!
    When reading all of these posts, a question has come up--Is there such a thing as a list of all the fasteners on an 08 RT? For example, when compiling a toolkit, I don't want to carry a 19mm wrench if there's no 19mm nut on the bike. Conversely, I'd like to have a wrench/socket/extension/bit to get to everything I need to.
    Any way to know all the tools needed specifically for THIS bike? Short of taking everything apart?
