Results 1 to 7 of 7
Thread: Looking for Diode board
    Registered User coyotebmw's Avatar
    Feb 2004
    Newcastle, WA
    I am looking to find a good replacement Diode board for my 1983 R80RT. Other than an original BMW board, I am looking at possible after-market replacements that may be more resilient than the original. I have heard that there are some out there, does anyone have a suggestion. I found one called a "Thunderchild Heavy Duty Diode Board" for about $90, anyone have experience with this product. I was also told of another one by a parts worker at the local BMW shop, but can't find the card with the name on it. I know an OEM BMW Diode Board is about $106, but supposedly some of the after-market ones are better.
    CoyoteBMW
    53 years of BMW's - 1960 R26 and 2007 F800ST!
    BMWRich58
    Aftermarket is the Kat's Azz!!!
    Thunderchild and the other is made by MotoEletek or something like that.
    Either, or,.. is way better than OEM BMW,sorry....BM....
    When replacing the diode board, replace the rubber mounts with the "solid one's". Recommended by all "airhead guru's" Better "heat transfer" longer life for the board........!
    Registered User kioolt's Avatar
    Maryland
    Try the following site.
    http://www.motoelekt.com/
    2004 R1150RT 165,000 miles , 1991 K100LT 128,700 miles, 1982 R100RT 106,900 miles
    Total 400,600 BMW miles
    AMA,BMWRA,BMWMOA
    The cheapest thing on a BMW is the nut that connects the handlebars to the seat.
    Feb 2004
    Newcastle, WA
    Thank you, I think this is what I was looking for.
    Tom Pemberton
    CoyoteBMW
    Registered User R100RS's Avatar
    Jul 2003
    North Florida
    From what I've heard, Thunderchild is the way to go.
    -Mike
    '02 R1150R
    '88 R100RS
    MOA,RA,ABC,NEF,MCPR,MOAL brownie's Avatar
    Oct 2003
    Pensacola, FL
    Thumbs up Thunderchild
    Agree with all-have had mine for 4+ years..........have mine installed on the "side cover". Took 4 bolts, JB Welded the heads to the cover in the EXACT right position. Slipped the Thunderchild on the bolts, and voila!!!!!
    Ofcourse the 3 phase wires must be extended from the alternator, but very simple task. I also recommend doubling the ground on BOTH blades of the diode board.
    This system has worked for over 50K in VERY warm riding conditions. Airflow behind the cover is significant.
    Regards.................Shep
    Words to Ride by: Patience, Anticipate, Paranoia
    Shep Brown MOA 27510
    "Igor" 82 RS "Inga" 04RT
    Pensacola, Flairider
    Feb 2004
    Newcastle, WA
    Thunderchild and Gen light
    Well I finally got the Thunderchild diode board and installed it yesterday. I fit right in and had very good instructions with it. My problem with the generator light glowing dimmly has gone away!!
    CoyoteBMW
