Results 1 to 6 of 6
Thread: What's the scoop on clearing an ABS fault?
    What's that noise...? basketcase's Avatar
    Alabama
    A friend has a '94 K1100LT, and the ABS lights are blinking -- non-stop.
    I've read the articles on the Internet BMW site, but they don't seem to address the later model K's.
    Is it the same procedure, or is there another trick to know about before putting a jumper in the plugs?
    Thanks,
    Rick
    '98 BMW Z3 Roadster, '00 R1100RT
    If you insist on exercising a right to burn our flag, first be so kind as to wrap yourself in it and then douse yourself with gasoline just before you strike the match.
    bmwmick
    Rick,
    Go here:
    http://www.largiader.com/abs/absfault.shtml
    Before you reset it, read out the faults.
    Mick
    Alabama
    Thanks. I'll read it myself, but will pass it on to the other guy, as well.
    On the Road
    Mar 2004
    New Rochelle, NY
    Hello everybody. I have a question that is kind of long, please bear with me...
    Turn on switch
    - middle red light (triangle) --> solid
    - ABS blinks
    Press both brakes
    - middle red light and ABS light blink alternatively (one, then the other, then the other, etc.)
    Start bike and move about a foot or two
    - both lights go away
    Is that the way they should blink? I am talking about the red section in my post. Is this how they should blink or both at the same time?
    Thank you for your time,
    Harry
    West Salem, OH
    If the lights stop blinking after you start moving, it is just the abs making sure the sensors work, and it is normal. If they alternate blinking after starting, try stopping and shut off the engine and restart it. My roadster used to do that if the battery was low, and restarting would clear it.
    Gale Smith
    2009 Versys
    1999 R1100RT
    On the Road
    Mar 2004
    New Rochelle, NY
    Thanks.
