Results 1 to 8 of 8
Thread: those BMW signs, on the engine
    Rally Rat donkey doctor's Avatar
    Sep 2003
    Vancouver Island
    Hello; I got the engine real hot in Edmonton last august, so hot that the signs that stick to the side of the engine fell off. I lost one in a busy intersection, so I yanked the other one off and stuck it in my tankbag. Now I'm ready to put them back on, but what should I use?
    I think the signs were stuck on to the case with clear silicone, shich should have worked, but didn't. The high temperature silicones don't have the glue factor of the others.
    What would You use to stick these things back on with?
    Mar 2004
    Kansas City, Mo
    Use a good slow set (1 hour), filled (not clear), epoxy. Set both decals on with a little tape to keep them from sliding down and adjust a few times during the set up time. Permanent to 300F.
    I work with hysol brand alot. Great stuff.
    Dan.
    Has the GS-Lust The_Veg's Avatar
    Sep 2003
    Atlanta 'burbs
    I've also heard that a product called Gorilla Snot works well for this.
    2012 R1200GS
    "If you can't fix it with a hammer, it's electrical." -somebody's dad
    Sep 2003
    Vancouver Island
    Hello; I'm not sure if 300F is enough. I remember that when the signs fell off it was surely hotter then 300F. I was stuck in slow moving bumper to bumper traffic for about an hour on an already hot day.
    That gorilla snot stuff, we have an anti-sieze compound here that is called gorilla snot, surely not what you were thinking. It's on the same shelf as the panther piss ( pernetating fluid) and the whale sperm (pipe thread sealant).
    Registered User jgr451's Avatar
    Jul 2003
    Left Coast Canada
    I used a 2 part epoxy glue when mine were about to go south.Too bad you lost yours!What did it cost for a new one?
    srb
    If your engine temp is 300, I think those little signs are the least of your worries. I thought that the danger zone started at about 250. Of course I could be mistaken.
    Sep 2003
    Atlanta 'burbs
    No, the Gorilla Snot I'm referring to is I think a weatherstrip adhesive but don't quote me on that. I think Gorilla Snot is it's real trade name too, but I haven't actually seen it anywhere. But some of the guys on Boxerworks.com swear by it.
    2012 R1200GS
    MOA,RA,ABC,NEF,MCPR,MOAL brownie's Avatar
    Oct 2003
    Pensacola, FL
    Unhappy Ouch!! Sounds Hot!!!!
    Dear Doktor............I'm no techie or Guru, but have ridin' Airheads in the Sunny South (84F today) for 25 + years......
    If get caught in the typical winter "Snowbird" express, or major stoppage on interstate, I pull as far over to the right of the pavement, I shut my headlight off for LESS conspicuity, and putter (5 mph) past the stopped traffic.
    This is of dubious legality, and certain to PO a LEO, but you have to keep your eyes open for the LEO's. I have found that "most" drivers don't get grossly mad, if you pass them with a little respect. To sneak back in when neccesary, I wait for the "right" type of driver, wave politely, and always get back in.
    If you are "really" stuck in traffic.......pull over and snooze, or get somewhere bearable..........but please ,IMHO, do NOT idle for long periods, clutch in/out in creaping traffic!!
    Yes I do have a cooler w/thermostat, but I will not let my oil go over 250F....................Shepster
    Words to Ride by: Patience, Anticipate, Paranoia
    Shep Brown MOA 27510
    "Igor" 82 RS "Inga" 04RT
    Pensacola, Flairider
