Results 16 to 30 of 34
Thread: Fun with Polarizers
  1. #16
    Tucson, AZ, & Madison, WI
    Quote Originally Posted by bricciphoto View Post
    Amen. Black skies on sunny days aren't cool.
    Question: Is the sky in the photo below too "black?"
    Personally, I like the sky's color. Of course, part of it is due to being in Arizona, where the sky is usually a deep color, and part is due to the exposure meter reading the white bike, thus darkening the sky.
    Jeff Dean − BMW MOA Co-founder (1972)
    '15 R1200RT, '15 R1200R, '07 R1200RT, '67 R60/2, '55 R67/3, '54 R51/3, '54 R68, '49 R24
  2. #17
    Rally Rat torags's Avatar
    Apr 2005
    SF Bay Area
    Polarizers are a necessity for mid day shooting.
    But there are other occasions when they're important.
    I have both the Cokin set up for linear polarizers and a few circular polarizers for each lens.
    I use the cir for mid day to get blue in the sky. On one occasion both the cir and linear were appropriate. That was at the Bonneville salt flats where the ground was absolute white and full of glare & the sky was bleached.
    If you want a sunset and want to keep some detail in the foreground (rather than silhouettes) then a linear polarizer will help. I have a graduated Cokin that goes as dark as 3 stops (you can adjust to 1 or 2 stop).
    But make sure you don't just slap either polarizer on and expect it to work; you have to adjust it, which is easy to do.
    This is the best example I have of the value of linear polarizers. I got fog detail in the foreground while reducing the super glare of the sunset to get a definitive orb
  3. #18
    Canada and the Alps
    My filter is on all the time. It protects my lens and does what a polarizing filter is supposed to do.
  4. #19
    Registered User widebmw's Avatar
    Reno, NV
    I think the most polarizing is the K&N versus stock paper argument.
  5. #20
    Aug 2004
    SE Michigan
    Quote Originally Posted by bmwdean View Post
    Jeff, I'll take a stab at answering your question, but it's really a matter of taste more than "too black". In my opinion, the sky seems unnaturally dark, particularly in the upper left hand portion. When showing a wide expanse of sky a polarizer will often yield uneven results unless the entire sky is at roughly the same angle from the sun. I'm guessing you may have used somewhat of a wide angle lens for the shot, and the polarizer is not able to provide an even amount of polarization across that vast expanse. But maybe you already know that. By the way, I love the shot, regardless of the technical nit I'm picking!
    Dan
  6. #21
    Feb 2007
    Orlando Florida near UCF
    This is something I have explored for years. Polarizing filters are a great tool for bringing blue skies into rich colors and not bleaching them out by over exposing. They also work great when shooting great bodies of water with glare and shine. Even sunsets. There is a bit of a science since wide angles, zoom lenses and fixed lenses, all react slightly different. You can turn the polirizer to an angle where you are pleased with the image. With a polarizer filter, you are in control. Promaster carries one that's made by Hoya, which is a Tokina company. It's a pretty darn good filter. Cokin, Tiffen, and B+W are also great. I have never had a B+W, but have heard they are the best from other collegues.
  7. #22
    Hey Jeff, Because you're quoting me, let me add my two cents. Yes, the sky appears unnaturally dark, but a polarizer can turn a blue sky almost black. Your sky isn't quite there yet. I can't tell if you cropped your shot or not, but the sky isn't equally dark on each side, which could be due to the polarizer not being rotated to balance the corners, or from cropping. The R60/2 is perfectly exposed and unfortunately that forced your sky to go a bit dark. A graduated neutral density filter across the bottom of the frame would have yielded a more natural looking and better balanced exposure in my opinion, but It's a great shot and I love the color of the bike against the blue sky. It really is an excellent demonstration of the utility of a polarizer, minus my two minor criticisms--recognizing it's a difficult task to manage that much contrast in a single exposure.
    I'm sure if I looked I could find an example of a black sky somewhere in the great expanse of the Internet. They're usually shown in the photo mags in "what not to do" scenarios, too.
    Ben Ricci
    Rides & Drives: '07 BMW F800ST Low, '07 Porsche Cayman, '06 VW Jetta TDI & '05 BMW R1200ST
  8. #23
    Just adding some additional thoughts on the discussion above. The black sky effect is particularly acute with super saturated high contrast transparency film coupled with extreme wide angle lenses (<20 mm). Super wide lenses also bring a whole host of issues regarding filter size, vignetting, etc. into play. I'm thinking of Fuji Velvia 50 specifically. I have no idea how the various digital sensors stack up against transparency film in terms of saturation and contrast. I'll see if I can find an example of what I'm talking about. I've probably shot a few over the years, but it's doubtful I kept the transparency (for obvious reasons ).
    This isn't Velvia, it's a Canon 1Ds sensor, but it is a high contrast scene using a polarizer. I used this shot as an example of what happens to snow and skies with a polarizer in my photo class. You can see it's difficult to expose the sky, snow and highlight (edge of drift) correctly in one exposure. Had this been shot with Velvia, the sky would have been almost black. You can see the sky isn't really blue at all. The snow isn't purely white because it's reflecting the blue sky. Hope this helps.
    Ben Ricci
  9. #24
    SNC1923
    Ben,
    If you don't mind, I'll give it a shot. I have a few photos that I think are examples of what you are talking about.
    These are all shot with a 40D and a 10-22mm zoom. At the wide end, that's a 16mm equivalent (IOW very wide-angle). All shot with a B+W circular ploarizer.
    The polarizer here is adjusted for maximum saturation of the sky. Clearly, it's too dark.
    Roughly the same shot, backing off on the polarizer quite a bit. Sky is still unnaturally dark, but it is a more realistic photo.
    Same thing: Too dark.
    A change in orientation and in the adjustment of the polarizing filter, resulting in a more naturalistic image. Click for EXIF. The exposures in the first two are equivalent; in the second two, identical. The last two photos are underexposed, the LM being fooled a bit by the white rocket. Had I to do it again, I'd add +2/3 EV.
    Vignetting (dark corners) is not apparent to me in any of these shots, but might be against a lighter background--modern lenses vignette quite a bit. Processing programs like LightRoom even have settings to deal with it.
  10. #25
    Those are good examples Tom. Thanks for helping out!!!
    Note the rocket in Tom's last two pics is fighting underexposure while the sky is less saturated (similar to my snow example above). This is very difficult shooting territory even for a pro as it's really pushing extremes into one exposure.
    Here, this is Velvia and I'm pretty sure no filtration at the Bonneville Salt Flats. Yucky black sky. There's probably 7 stops difference from the top of the frame to the bottom--maybe more .
    (Sorry for beating this nuance to death. )
    Ben Ricci
  11. #26
    Yucky black sky.
    I guess I am all washed up. I like it. Has an other-worldly feeling. Neat.
  12. #27
    I guess this photo of a 1952 BMW R51/3 would qualify as a yucky black sky
  13. #28
    Here's the same scene with a better exposure. Almost makes me want to go out and shoot some positive film again.
    Ben Ricci
  14. #29
    I plan re reshoot my "yucky black sky" photo above again without a polarizer, and will post the result. The polarizer can, I confess, over-darken the sky, and does over-saturate the black on the motorcycle. I will be interested to see how the same photo without the polarizer changes things.
    BTW, the photo with the white motorcycle seems to come out better with the polarizer than the black motorcycle.
  15. #30
    Here is the similar view show with no filters at all. Compare to black sky above. I confess that I like this better.
    One should be careful using a polarizing filter. As Ben said, it can turn your sky black. It can also over-saturate colors, causing then to become too dark, and can alter the colors. And, depending on the quality of the filter, it can reduce the crispness of the resulting image. I noted that my Hoya circular polarizer did reduce slightly the sharpness of the details on the motorcycle, such as the BMW roundel, and tends to make everything slightly greener. Perhaps I need a higher quality filter.
    I see they can be pricey -- http://tinyurl.com/3cos3y
