Results 1 to 8 of 8
Thread: G9 pano shots
    rocketman
    G9 pano shots
    I've been playing around with the G9 pano feature while on vacation in Balize
    and while on board the ship we took there, and am pleased with the way it
    functions and that you can shot a full series of shots in either direction, i.e panning
    left or right. Here is the first, a pano of the main plaza at the Mayan Palace in Balize,
    about two hours in land from the coast. Ignore the text overlay I haven't gotten my key
    for the software yet so it was made with the trial version.
    more coming...
    RM
    bensonga
    Hi RM,
    Could you tell us more....exactly how you did this? Did you use a special tripod with a panoramic head, etc etc? I'd really like to know what the procedure is, in detail, for creating a panoramic photo like this with a camera like the G9. Might be time to upgrade from my G2. I've wanted to get into panoramic photography and this looks really good!
    Gary Benson
    Eagle River, Alaska
    grossjohann
    Quote Originally Posted by rocketman View Post
    RM
    Looks like a great spot for the G9, Jeff.
    I'm also interested in how it works. There seems to be some optical distortion in the upper corners. Is that from the lens? Its nothing that cant be cropped out while still preserving the pano, but it would be great to get the full effect.
    Thanks,
    Alex
    rocketman
    Basically the Canon G9 has a feature that allows you to take a picture
    then it shows you the image on the screen with a blank area next to
    it that displays the next image (what the camera is pointing at) live
    as you pan the camera back and forth when you get the next one lined
    up with some overlay you snap that and the display then moves to the
    next frame and you repeat. Not sure how many frames you can take
    but I took as many as 7 and it kept going.
    I just hand held the camera, and just alined it horizontialy as best I could,
    no tripod or pan head though that would help I'm sure. I did note that the
    more overlay between frames the more it tends to bend the image (note the
    left hand side is curved somewhat more than the right, that is because I had
    more overlay in the first few shots. I will upload the individual shots this evening.
    I haven't seen that in other
    cameras, but I'm sure there are others that do this.
    Then when I got home I stitched them together using Pixtra software.
    RM
    grossjohann
    RM
    Thanks, Jeff.
    That makes more sense to me. It's not optical distortion it's the Pixtra software stretching the image to fill the pano frame.
    -Alex
    rocketman
    Quote Originally Posted by grossjohann View Post
    Thanks, Jeff.
    -Alex
    Hmmm, now that you mention it, I'll try cropping the second shot in the series
    before running it thru with the registered version and see if that makes a differance.
    It was somewhat hard framing the overlays while trying to maintain
    the horizontial framing since it was done hand held, so the second frame is
    a least half overlay of the first, the rest were maybe 1/4 overlay from the preceeding frame
    as shot.
    I'll post the new version when I've redone it.
    RM
    rocketman
    second version, using the registered version of the software
    and cropping the second photo in the series to cut down on
    the overlayed area. Seems to have improved it a bit. Not quite
    as much curvature in the left of the pano.
    RM
    rocketman
    Pano number three Sky shot from ship
    this one was a good bit harder to stitch, I had to process the files
    some to lighten them and get them more even in tone as I was
    shooting at dusk and as I panned away from the sun light it got
    darker, plus with the rocking of the shp the horizon was tilted in
    each shot, so I had to straighten them. since the ISO was set to
    auto you can see the picture getting more noisy as it pans to the
    right. Plus the fact that the clouds kept changing shape (darn them!)
    I had to manually aline the shots in the stitching software. with some
    more work I could probably get a better result, still nor to bad for my
    first attempt with this set of images, five in all.
    fun stuff..
    RM
