Results 1 to 3 of 3
Thread: Fuel Crossover Quick Disconnect
    Removing the fuel tank is much easier if you install a fuel quick disconnect in the crossover hose. I've been using the plastic quick disconnect for the K series.
    I recently discovered the quick disconnect is made in the USA by Colder. They also make the metal versions of the connector including chrome plated brass. The image below shows different inlet and outlet diameters:
    Check out the various connectors at:
    When showing your bike, simply reinstall the original crossover hose.
    Administrator 20774's Avatar
    What, you don't like a gas bath every once in a while?
    what is the dimension of the standard crossover fuel line for a 1968 R60US?
