Results 1 to 15 of 19
Thread: Fuel Line Quick Release Coupling - a good investment?
    On the Road
    Dec 2005
    West Seattle, the land that time forgot.
    A&S BMW sends me email-offers from time to time, the latest being a fuel line quick release coupling that is "Die Cast Zinc and Nickel Plated". Does anyone have any opinions of this being a a good investment or a waste of money?
    The reason I'm asking is that I've been led to believe the stock couplings for my 2003 R1150R are a little fragile and could be improved upon.
    They can be found here:
    http://www.ascycles.com/detail.aspx?ID=47556
    couplings
    In my experience the stock couplings are a little fragile but should hold up well if handled with care when removing and refitting.
    Canada and the Alps
    Quote Originally Posted by 110164 View Post
    None of the fittings on my 2003 and 2004 GS Adventures have failed.
    Most are probably failing due to some owners trying to force them together (who knows, maybe even with pliers ) because the O-rings have swollen a bit.
    Get a pack of 20 AS568-011 O-rings from your local supplier for $2. With new O-rings, the original couplings just slip together; no force or cursing needed.
    Registered User awagnon's Avatar
    Jun 2004
    Ogden, Utah
    There are countless reports on the BMW Sport Touring and Adventure Rider forums of quick disconnect failures. Mine on my 2004 1150R broke spontaneously, but fortunately, I was close to home. The male part of the plastic connector breaks off quite easily. There are many threads on the other forums about different replacements. I replaced mine on both bikes with Omegas. Here is just one link, but there are many other threads if you do a search. I would replace them if I were you. Even BMW now recognizes the plastic ones are crap.
    http://bmwsporttouring.com/ubbthread...page=0&fpart=1
    Al - Ogden, Utah
    Boxer bikes, boxer dogs, and letterboxing.
    2002 1150RT
    2015 Triumph Tiger 800XRX
    Twin Cities - MN
    Where's Darcym?
    IIRC, Darcy had a failure on her R1150R, and ended up replacing hers.
    Brad D. - Member #105766
    '94 R1100RS - Sylvia
    DallasRTRider dallaskrsrider's Avatar
    Dallas
    Quick Disconnector
    So does the R1100RT have one or two quick disconnectors? I'm assuming two, it's not my bike.
    And I can tell you that those guys do break, with no notice, and suddenly your boot is soaked with fuel.
    Ken Bowen--2011 R1200RT
    MSF RiderCoach
    MSTA 8427 BMWMOA 104748
    The quick disconnects are made in the USA by Colder. They also make these connectors in aluminum, zinc die-cast and chrome plated brass.
    Pictures and info for the metal versions at:
    http://www.colder.com/Products/Metal...5/Default.aspx
    FYI
    Registered User KALTZG's Avatar
    Aug 2004
    Crestview, Florida
    Forget the plastic and the zinc
    Go with solid brass at Small Parts Inc. These puppies are great!!
    http://www.smallparts.com/products/d...tions/2170.cfm
    Gail Kaltz
    1997 GS
    Couplings
    Replace with the Omega stainless before they fail, as mine did on the day the wife and I were planning to go on a long ride. You wont be sorry.
    medieval
    which coupling ???
    Do I get the double shut-off, or the single? If it is the single, which way do they install??? Thanks.
    On 2004 RT, how many pairs of connectors would there be (I take it would be two) and what are the fuel line size 1/4", 3/16" etc.
    Jun 2004
    Ogden, Utah
    Quote Originally Posted by 04r1150 View Post
    I presume the '04 RT is the same as the '02RT and '04 1150R. It would require two male and two female connectors. The hose inside diameter is 5/16 inch.
    Al - Ogden, Utah
    2002 1150RT
    Whichever ones you go with....
    Mount them opposite directions of each other so that you can hook them back up with out having to remember which hose from the tank goes to which FI.
    On the Road
    Dec 2005
    Good one, Dadodirt
    The simple ideas are always the best. Thanks.
    Jul 2005
    Dameron, MD
    OK, I broke the male connector, the sleeve ended up inside the female connector and I was dumping fuel all over my driveway (when I tried to put it back together)
    Now I want to order the metal connectors but the A&S site says "Allow 2 weeks for us to process your order".. I REALLY don't want to be down and out for 2 weeks awaiting parts. I don't stay down that long for winter.
    HELP!
