Results 1 to 11 of 11
Thread: F 650 aux lighting
    Sep 2006
    F 650 aux lighting
    I am looking to replace the Piaa 1100 X lights on the 650GS...too many watts for the output of the charging system...cannot keep up. This old electrician didn't do his homework on this bike! What are you using? I would prefer to just swap the lights and leave the existing Piaa wiring in place.
    Steve Henson
    Unavailable for comment
    Apr 2007
    Wolverines released
    A couple of options I am looking at or considering are an upgraded alternator or an upgraded alternator and an extra battery like the police version. A capacitor may be another option, but I don't know that there is one available for a bike.
    I especially like the thought of an extra battery as running heated grips and vest in town even without the lights is taxing. And, on my CS, I'll be relocating the existing battery for certain when it's warmer out.
    Braintree, MA
    Different bike here, but limited watts. I'm using one Piaa 1100x and one Hella fog, independently switchable. I figured it was a better solution than extra lighting at 2 x35 watts.
    -Tom (KA1TOX)
    Rally Rat PAULBACH's Avatar
    Dec 2005
    I had a CS and loved the machine for riding and handling. The gas mileage would get close to 70 mpg.
    But the electrical system was anemic at best and twice the bike died due to electrical - under warranty thank goodness.
    I once died out in the middle of no where. Fortunately I was able to coast down a small hill where I spotted a motorcycle under a cover. The Harley Davidson owner got out jumper cables and got me going again.
    I traded the 650CS in and got one great deal on an R1200 GS. Even if there was space for an extra battery on the CS I'm not sure the charging system is up to the task.
    Keep the forum posted if you are able to affect any good changes in the electrical system.
    Apr 2007
    Wolverines released
    Quote Originally Posted by PAULBACH View Post
    The extra battery ala the police model I'm putting on the '99 F650 but my '05 CS, I'm just going to move the battery.
    Once it's a little warmer, I'm designing and building a battery holder for the top front. I'll still run a vent tube down and out so as to be able to put the rucksack in the same place since it's flexible. The CS is just a PITA to put water in. I end up having to take the battery out each time which involved taking both sides off. That's not so bad - it's getting the battery out and back in and removing the pos terminals.
    But I like that other solution of independently wiring fog and driving lights. How were the switches mounted?
    Braintree, MA
    Quote Originally Posted by rkasal View Post
    Depends on your bike. You could do something fancy with an autoswitch and tap into your existing switch wiring. I'm using toggles with weather boots near the clutch switch cluster on my Vstrom. I'm also using switching relays from Eastern Beaver.
    -Tom (KA1TOX)
    Yellowjacket
    Smile Have you looked at the PIAA 510 lights?
    I'm using them on my 05 650GS and they work great. I use a Kisan Charge Guard to monitor and power manage my electrical system and the lights don't seem to drag it down unless I've got the heated grips and a heated vest on too. It really depends on what other things you've got running when the lights are on. The Charge Guard lets me determine which things I can configure to keep my electrical system happy.
    Sep 2006
    Quote Originally Posted by Yellowjacket View Post
    Thanks, will look at them. We had issues with everything running....grips, vest & lights and it just did not keep up.
    Steve Henson
    If I recall - those lights use an H3 bulb. You might look at an HID H3 conversion that uses the same lights; mounts the ballasts somewhere, and inserts the HID capsule in the light instead of the H3 bulb.
    Sep 2006
    Paul, you referring to the 1100XX or the 510's?
    BTW, had the FD big seal replaced on Helen's 1100...all is good! The Dino just would not quit dripping either.
    Steve Henson
    Mar 2008
    Burien, WA
    Smile Auxillary Lighting on F650
    I installed a pair of HID lights that I obtained from www.blmaccessories.com. I built my own mounts and used a switch from www.electricalconnection.com .
    Switch (underside):
    Tim in Burien, WA
