Results 1 to 15 of 23
Thread: k75 shocks
    Registered User drrider's Avatar
    Sep 2003
    Indianapolis In
    k75 shocks
    after 97000miles the rear shock in my faithful old k75rt has about given up the ghost Has anyone tried progressive suspension's shock?::
    Focused kbasa's Avatar
    I had a really nice on on my K75. I think it was a model 420? It had a remote reservoir and both preload and damping adjustment.
    It completely transformed that bike. We also had a Koni on Tina's K75S, but it was ridiculously harsh.
    Dave Swider
    Marin County, CA
    Mar 2004
    Alexandria, VA
    Re: k75 shocks
    I have a Works Racer on mine. It works well, is rebuildable, and fairly inexpensive. They will set it up for your weight with the proper springs and it can be adjusted.
    Jim
    MichiganMike MICHIGANMIKE's Avatar
    Hudsonville MI
    Question Source for Shocks???
    So with replacement shocks, where are you purchasing shocks other than normal local dealer? Any good dependable on line sources? Looking for new not used shocks at this point, unless I could get a really good deal on a low mileage used one. I'm 6'3" 215# with jacket etc.
    Spring Lake NJ, USA
    Re: k75 shocks
    Had a Progressive 420 on my K100RT.. it didn't work well for me.
    I've had the following, in increasing order of satisfaction:
    Stock - over spring/under-damped
    Progressive - Way over spung and they wouldn't do anything about it.
    Works Performance - good shock, built to you - but needed frequent rebuilds.
    Ohlins - good shock, can be rebuilt at any dirt-bike suspension shop. Expensive, but worth it. I don't believe they still make a model for the K75's.
    Wilbers - excellent shock, in some ways better than the Ohlins, and slightly less expensive. Built to order, more adjustments than Ohlins. They do make one for K75's/K100's. DISCLAIMER - the importer of Wilbers is a good friend and used to own my current K75S.. plus I gave him some help with his website. Doesn't change my opinion - it's a better shock than the Ohlins, and that seems to be a very common opinion from anyone who has owned both.
    rabid reader dbrick's Avatar
    Santa Cruz CA
    I had a Fox on my K75S, and found it just awesome. Kinda spendy, but much less than Ohlins or Wilbers. If I had a K75, I'd buy one again.
    David Brick
    Santa Cruz CA
    2007 R1200R
    Rally Rat YB in IN's Avatar
    Bloomington, Indiana
    Be sure to think about new fork springs as well. I put a Progressive on the rear of my bike, and it made the front end start to feel like a pogo stick. Progressive makes some stiffer fork springs that are supposed to be decent that I'll be purchasing here real soon. If you need a shock though in the meantime, buzz me off list I should have my old stock spring laying about.
    West Salem, OH
    Fox no longer makes road bike shocks. They will still support the existing ones, or so it says on the website.
    Gale Smith
    2009 Versys
    1999 R1100RT
    Works Performance has a nice set of dual rate fork springs for the K75.
    Frank G.
    Hattiesburg, Mississippi
    2004 R1150RT
    Registered User breyfogle's Avatar
    Aug 2004
    Lomita (aka L.A.), SoCal
    I've had a Progressive on my K75S for years but I have to agree with most of what has been posted before. Progressive 420's seem to be damped too light for the spring. When new you can set the compression and rebound to their max and it will work OK but as the shock wears it becomes underdamped. I've had it rebuilt twice but can not get them to increase the low speed rebound damping.
    Registered User jcpuckett's Avatar
    Apr 2005
    Beaumont, TX
    I just bought Tom & Rosie Sperry's 1992 K75. Fly to California to pick it up on October 1. I had Wilbers on my 1150RT that I bought from Klaus Huenecke and rebuilt by him last March. Where can I buy Wilbers for my K75 now that Klaus does not sell them?
    Jim Puckett
    www.notsupermanrally.com
    IBA 24142
    MOA 112409
    Spring Lake NJ, USA
    Quote Originally Posted by jcpuckett View Post
    Jim - you might contact Klaus and ask about Hyperpro shocks. The price may (not sure) be less than Wilbers, and it is an equivalent shock..
    Nov 2007
    Montpelier, VT
    I just checked the Hyperpro web site and they don't seem to list any shocks for the K75 or any other K bike.
    Spring Lake NJ, USA
    Quote Originally Posted by kpinvt View Post
    Kevin, don't believe everything you read on the Interweb.. call him.
    Boise, ID
    Klaus also sells YSS
    With all this talk about Klaus, I'd remind folks that he also sells YSS shocks. I bought a YSS for my K75S about a year ago through Tom Cutter (who got it through Klaus). It looks like a very high quality product, threaded pre-load adjuster, 60-click rebound adjuster, came set up almost perfectly for me, and works, very, very well. It only cost me $375 and I would say you'd have to spend half-again, if not closer to twice as much to get something comparable. It might be worth while to ask Klaus about these as well as the Hyperpros.
    Greg Feeler
    BMW MOA Director & Ambassador
