Results 1 to 6 of 6
Thread: K100LT Speedometer malfunction
    78184
    I have a 1991 K100LT with an intermitent speedometer malfunction. Sometimes it works. Sometimes it just sits. Other times it appears to do the hula. I am looking for suggestions for repair.
    Focused kbasa's Avatar
    This is a pretty common problem with Kbike instrument clusters. I used to punch the one on my K75, which would make it start working again, but after a while my knuckles would start to hurt.
    Finally, I wandered over to www.ibmwr.org and poked around in their tech articles. They have a series of fixes for Kbike instrument clusters. I'd bet you'll be as successful as I was.
    Dave Swider
    Marin County, CA
    78184
    Vielen Dank!
    Registered User kioolt's Avatar
    Maryland
    Before you do all of the harder cures try reseatting the plug behind the side cover for the sensor on the rear drive.
    2004 R1150RT 164,500 miles , 1991 K100LT 128,500 miles, 1982 R100RT 106,900 miles
    Total 399,900 BMW miles
    AMA,BMWRA,BMWMOA
    The cheapest thing on a BMW is the nut that connects the handlebars to the seat.
    Rally Rat gstom's Avatar
    Joplin, Missouri
    Thumbs up Ditto
    I had an intermitent problem with my speedo ('88 K100LT) that has gone away after popping the sensor plug, giving it a good wipe, and replacing it.
    BRAHMA
    on my '85 K100RT, I've cleaned the connections really well, and placed a light coating of dielectric grease on them about once every couple of years. Only drops once or twice now on the hottest days of the summer.
    DSD
