Page 1 of 3 1 2 3 LastLast
Results 1 to 15 of 34
Thread: Gas cans mounted in from of Pannier
    Continually Confused RogerA's Avatar
    Apr 2007
    Deland FL
    Hi:
    I am planning on mounting gas cans in front of the BMW panniers on my R1200GSA, similar to the picture shown (different brand of panniers of course).
    Are there any kits available? Anyone have experience with doing this?
    Advice would be appreciated.
    Roger
    2011 R1200 GSA
    1972 R75/5
    2009 Triumph Thruxton
    MOA/IBA/AMA
    RIDERR1150GSADV
    Talking
    I mounted a few MSR fuel bottles on my TT boxes and find it works fine. How much extra fuel do you really need with an Adv anyway??? the 3 quarts or so I carry were enough to get me out of a bind in the Yukon this summer, but encountering an entire town being out of gas doesn't happen often either...
    Kolpin makes fuel tanks that should fit on your bike too.
    Apr 2007
    Deland FL
    Quote Originally Posted by riderR1150GSAdv View Post
    This is the setup I used for the last Prudhoe bay trip:
    Most of the gas if for for my wife's R1200GS, plus a couple of gallons for me.
    This setup is top heavy, especially when I am carry four tires as well (you guessed it, 2 for me and two for Kathy) so anything I can do to lower the CG will help.
    Roger
    2011 R1200 GSA
    1972 R75/5
    MOA/IBA/AMA
    RIDERR1150GSADV
    Talking
    Carrying gas for two bikes poses a different approach. These may work on one or both bikes? One could be mounted on the backside of the right pannier on the GSA....http://www.kolpinpowersports.com/sto.../3/products/49 Just my 0.02 cts.
    Apr 2007
    Deland FL
    Looks interesting - I'll let you know how it goes.
    Thanks!
    2011 R1200 GSA
    1972 R75/5
    MOA/IBA/AMA
    thtduck
    A friend and I are planning a trip for this summer to Prudhoe Bay and I'm considering these custom mounts for the GS:
    PegPacker from http://www.bestrestproducts.com/
    http://www.bestrestproducts.com/c-114-pegpacker.aspx
    elkroeger
    Boy, I'd like to see that. I've been experimenting with some large hose clamps to mount MSR bottles on my saddlebags (like a fire extinguisher). I've almost got it, but I'm reluctant to drill the necessary holes in my bags....
    Urbana, IL
    Interesting stuff. Did you read how he made a deal with his friend to buy gas from his friends 11 gallon tank and post dated the check so he could stop payment on it? Not someone I would like to know.
    My other bike is a BMW.
    Rally Rat PAULBACH's Avatar
    Dec 2005
    Neat setup I saw at Hunter Mountain during Color in the Catskills
    Danger: Keep Back 500 Ft FredRydr's Avatar
    Jul 2005
    central Pennsylvania, USA
    I mounted a few MSR fuel bottles...
    That's what I do. The seal on these screw-top fuel bottles is about as secure as one can get, and the opening accepts a standard fuel nozzle (watch out for blow-back). I carry one in a case on longer trips.
    Fred
    Jul 2007
    THE BIG SKY
    Quote Originally Posted by PAULBACH View Post
    Boy, that's a lot of weight up high. The Peg-Packers mentioned in thtduck's post, in this thread, at least carry the fuel much lower. That has got to make a difference when it comes to handling.
    Kevin Huddy
    Tm Pterodactyl MT Outpost
    OUTBACKUFO
    only probelm with this set up is the wieght of the fuel is very high up...
    maike sure that you try and mount what ever system for extra tanks as low as possible in the the "weight Triangle" on the cycle... the cycle will handle much better that way when you get into or on to bad ans slimy roads..
    Rally Rat RTRandy's Avatar
    Feb 2004
    Dallas, Texas
    For what it's worth when trying to consider CG issues. Gasoline weights approx. 7.5 pounds per gallon.
    Jul 2005
    Quote Originally Posted by RTRandy View Post
    For what it's worth when trying to consider CG issues. Gasoline weighs approx. 7.5 pounds per gallon.
    And much more if it is leaded.
    Fred
    Sep 2006
    Those Peg Packers setups look really well thought out for large amounts of fuel carried low. Definitely brings the weight to the COG.
    I have some Touratech holders for the larger MSR bottles and mounted them in front of the TT cases. they come with nylon straps,but I added a ziptie to prevent easy walk-offs. I use them when crossing West Texas,not so much for me but for my riding partners R bike that "almost" makes the next station when they are 250 miles apart
    saw this set up on ADV rider...not mine...I mounted two in front
    Steve Henson
