Page 7 of 12 FirstFirst ... 5 6 7 8 9 ... LastLast
Results 91 to 105 of 169
Thread: Photo Assignment: Weekend 01/05/08
  1. #91
    grossjohann
    Night Cap
    Last edited by grossjohann; 01-20-2008 at 02:17 AM. Reason: Image lost when thread moved to Photography Forum
  2. #92
    Slowpoke & Proud of It! BRADFORDBENN's Avatar
    State of Confusion
    Finally got a few together
    So I took some shots. Okay a bunch of them. I learned a few things along the way also. I am having some trouble getting the white balance tweaked in. Here are the 26 photos straight out of the camera - all that I did was run the RAW photos through Lightroom to convert to JPG for upload to smugmug.
    So I understand the rules of not photoshopping, so here are the six keepers. But I wanted to improve the output a little more so I did white balance, crop, rotate, tweaks in Lightroom. I kept the file names the same so that they can be compared and "whipped".
    I figured out that I need more light, and probably a better background solution.
    My two motorcycle keys
    I did not like how close I got to them
    Here it is cleaned up some - just cropped and white balanced
    So I did some closeups holding the camera instead of using the tripod
    Here it is a little cleaned up
    A few more keys cleaned up - white balance, crop, rotate.
    So then I wanted to get Write to the point -
    Cleaned up
    Then it got a little skewed
    Cropped a little and WB
    Complete Galleries
    Six Tweaked
    http://bradfordbenn.smugmug.com/gallery/4123815
    Straight out of camera
    http://bradfordbenn.smugmug.com/gallery/4123575
    -=Brad
    It isn't what you ride, it is if you ride
  3. #93
    #13338 PGlaves's Avatar
    Failure?
    Look closely!
  4. #94
    sMiling Voni's Avatar
    This one's HOT!
    Voni
    sMiling
  5. #95
    This one's not.
    Voni
    sMiling
  6. #96
    Last one. But it's hard to stop.
    Voni
    sMiling
  7. #97
    rocketman
    It certainly is close-up, though nowhere near the minimum focusing distance (thank God). The expression on the young girl aboard the sidehack is priceless.
    I think its been photo-shopped!
    RM
    (girl on the the side-hack? where??? Oh, yeah, I see..... )
  8. #98
    Chairman of the hoard wmubrown's Avatar
    Nov 2004
    Kalamazoo, MI
    Quote Originally Posted by rocketman View Post
    nope, bullets never travel mere inches
    RM
    Sure they do... from the clip to the barrel
    John A. Brown - Kalamazoo MI
    '09 K1300S 'Zoot' (Wicked, bad, naughty, evil, Zoot!)
    '94 K1100LT 'Desert' (the horse with no name)
  9. #99
    RM
    RE photo #89 - there might be a lot of "alteration" here but I don't think it was Photoshop - more like Dr. Shop.
  10. #100
    No one?
    RE Tom's mystery tool - Torx bit! Straight on the business end!!
  11. #101
    SNC1923
    Quote Originally Posted by BradfordBenn View Post
    So I took some shots. Okay a bunch of them. I learned a few things along the way also. I am having some trouble getting the white balance tweaked in. . . .
    I took a look at these shots and saw a lot going on correctly. Good composition, excellent focus, etc. The white balance is really tough though. Like Brad, I also am learning LightRoom, an adobe file organizing software program. It offers the ability to substantially tweak your photos but doesn't even approach the complexity of PhotoShop, which is, well, cumberful.
    Anywho, I took a stab at further tweaking the above image and came up with this:
    This is by no means perfect and I'm sure there are others on our site who are far more familiar with these programs. I can't remember everything I did, but for the most part I fiddled a bit with color temperature, greatly increased the exposure, reduced contrast (unusual for me), played with sharpening a bit, and really cranked "lens vignetting." Most zoom lenses vignette a bit, that is appear darker in the corners. This is hard to notice unless against a light background and you are looking for it. LightRoom has a correction for this under "lens corrections" of all places.
    One of the chief difficulties with this image is that it's on a plain, white background. Camera light meters are engineered to register 18% gray reflectance. Anything starkly different than that (total white or total black) throws the meter off. I think the issue here was not so much white balance (maybe a little) but that your picture was underexposed because the camera's light meter was fooled. When photographing a plain white background (snow for example) one should OVERexpose by about two stops; conversely, a plain black background (a spotlit stage for example) one should UNDERexpose by about two stops. Counterintuitive, perhaps, but trust me on this.
    Did you have it set for centerweighted or evaluative? CW metering is the old-fashioned system used by cameras for the past fifty years. The evaluative system is a light meter controlled by a computer program trained to correct typical lighting problems like backlighting, white or dark backgrounds, etc. They're very good, but far from perfect.
    Post-processing is an art all unto itself and I've only begun to scratch the surface. I'd love to take a class one of these days. . . . . However, the knowledge about under- and overexposing high contrast backgrounds would negate the need for editing software to render the above image. Just sayin'.
  12. #102
    Registered User burnszilla's Avatar
    May 2004
    Redwood City, CA
    Salmander Ensatina
    Stephen Burns - 2007 R1200GS
    BMW MOA Lifetime Member
    www.burnsmoto.com
  13. #103
    Quote Originally Posted by Burnszilla View Post
    Salmander Ensatina
    Outstanding photo - looks like it came from a box of "premium" gummy worms. Excellent!
  14. #104
    Technical Question
    Technical Question:
    Sometimes when I click on "Quote" the reply includes the text and the photo I am replying to. Sometimes only the text shows up in the reply.
    In #106 - no photo! In #109 I got the photo.
    I'm guessing that it has something to do with an attached photo vs a URL referenced photo. Any clues??
  15. #105
    SNC1923
    Technical Question:
    Paul,
    Your assumption about attached vs. URL is accurate, I think; however, in this particular case, in #106 you were quoting a message in which the photo itself was quoted. I guess it only works when you quote the message with the original URL'd photo.
    Strictly speaking, not a torx bit. Sorry.
