Results 1 to 9 of 9
Thread: Garmin BMW Mottorrad III GPS Power Cord Installation
    EyeBiker
    May 2006
    Abingdon, VA
    I need suggestions/help with installing a power cord for my my Mottorrad III GPS (came as a kit for 1150RT) on my '07 R1200RT. The mounting hardware for the unit fits the bike perfectly and I have purchased a power cable (# 71607686670) which would attach the GPS unit to the CANBUS unit. Is this something I can/should be able to do or must it be done at a dealership? The dealer is 2 1/2 hours away. If I it is a simple plug in, as it appears to be from the cable, I would like to know how to proceed.
    Is it necessary to remove fairings? If so which, how is the cord routed in the bike, and is it a simple plug in to the CANBUS or must additional wiring be done, etc.?)
    Cal Miller
    Need for Speed rebus's Avatar
    Oct 2005
    Paso Robles, Ca
    Cal -
    If the power cord you purchased is the same as the one supplied with the 12RT kit, then your connection is very easy to make. There is power connector for the GPS located under the fairing near the center fairing mounts. It is attached to the frame with a zip tie and has a rubber plug inserted it to protect it from the elements. Just remove the plug and plug in you power cord, and you should be good to go. You can get to it from under the fairing without removing any parts, although there is limited room to manuever.
    If you can't find the outlet I will snap a photo of mine for you.
    Good luck. You do not need the dealer.
    Steve Sylvester
    Paso Robles, Ca
    EyeBiker
    May 2006
    Abingdon, VA
    Quote Originally Posted by Rebus View Post
    Cal -
    Thanks, Steve, My bike is in the carport and it's about 20 deg so i'l wait until tomorrow when I think we will get back to freezing. But it sounds like I should be able to find it.,
    Cal
    Dec 2007
    Portland, OR
    I installed my Garmin Zumo on my R1200RT using a touratech mirror mount and a power connector from BMW. I didn't need to take anything off, although it was a bit crowded. There is a thread at http://www.zumoforums.com/index.php?topic=2798.0 that has a lot of detail. I used that for the power connection, works like a champ. Took about 30 minutes, most of that was splicing the BMW connector onto the Garmin cable and carefully zip tying the cable along the handlebar etc.
    2008 R1200RT
    EyeBiker
    May 2006
    Abingdon, VA
    Smile
    Quote Originally Posted by kr70657 View Post
    Thanks. The photos were a great help. Thanks to you and Steve, you saved me a 5 hour trip and a dealer charge to make this relatively simple installation.
    Cal
    Kento
    Aug 2008
    Cincinnati ohio
    Lightbulb Thanks,
    [QUOTE=calmil;275523]I need suggestions/help with installing a power cord for my my Mottorrad III GPS (came as a kit for 1150RT) on my '07 R1200RT. The mounting hardware for the unit fits the bike perfectly and I have purchased a power cable (# 71607686670) which would attach the GPS unit to the CANBUS unit. Is this something I can/should be able to do or must it be done at a dealership? The dealer is 2 1/2 hours away. If I it is a simple plug in, as it appears to be from the cable, I would like to know how to proceed.
    Cal Miller
    [/QUOTE
    I just got a gamin 650 for my 1150 RT. Anyone know if there is a power outlet up front on the 1150 (04)?
    Mansfield,MA
    Quote Originally Posted by kenthoward View Post
    Hi Kent, welcome to the forum. Thanks for using the search feature to try to bring up info on your question. As this thread is in the Gear section-appropriately-if this new activity on an old thread doesn't get you an answer, try a post in the Oilhead section. As that is the bike specific area for your bike, that would be a place to check next. Again welcome and enjoy, Gary
    Mod Squad
    2009 F800GS 1994 TW200
    A common place to take power on the R1150RT is the parking light. Easy access. Comes on and off with the ignition. I think I powered a GPS and a radar detector directly from the light, but my memory could be wrong. I might have used it to trigger a relay, instead.
    A posi-tap or similar can be used to access power at the leads to the lamp.
    Kento
    Aug 2008
    Cincinnati ohio
    Cool
    Thanks Marchyman,
    I'll take a look under the fairing, got the chatterbox today- going to try to blue tooth everything- tired of wires. Ordered a Migsel fairing bar with ram ball to mount the gamin, but had to order it from England, seems like a clean solution.
    Will the "super moon" create super tides?
