Results 1 to 10 of 10
Thread: K1200LT clutches/lifespan;
    Polarbear Polarbear's Avatar
    Clovis,CA
    At 95K on my KLT,'01 model, the clutch still works just fine, BUT? How long I ask myself. I have not heard of too many folks talking about such and I wonder how far some have gone with theirs? I ran into one guy a few years back with 125K on a KLT, before he did the deed of clutch replacement. Any other long distance KLT owners here? I have towed a trailer about 25K total behind this bike and I consider myself very easy on my clutch, so I am expecting more life, into the six figures on the odometer. Hope, anyhow! You know these bikes are very very expensive to have a clutch job done at the BMW dealer. Its quite an extensive teardown of the bike. I have all the tools, but have no desire to dig in. As a mechanic, I have always prided myself on my ability to keep my bikes going, without much of any aide from the BMW shops. I surely would have never been able to afford my bikes without my ability to wrench a lot. The KLT has been no exception to my wrenches and my largest challenge of a bike, since I began 40 years ago and I grow tired of wrenching on the "faired" monster, so it goes away soon to my brother, who cannot wait to have it. Its one fine motorcycle and has much life left in it indeed, but I most likely will never buy another faired, mech. unfriendly bike like this. 800lbs. too, is a challenge I won't miss. Back to my GS's and my ever so faithful R100/7, which is my savior, regarding BMW's. Randy13233
    Curmudgeon nrpetersen's Avatar
    Sep 2004
    minnetonka mn
    Yeah, at 69 I have a 2005 K1200LT, but I'm keeping my bare-bones '75 R90/6 for when I get really old.........!
    Loading the Bike
    Feb 2007
    East Bay S.F.
    clutch failure k1200lt
    The clutch on my 01 is slipping at 25,000 miles in 5th gear around 5000 rpm. I understand it is probably from a seal leak from the engine bearing and is a $1200 to $2000 repair. I'm thinking I should just push it over a cliff and buy a Goldwing.
    ltnelly4you
    Quote Originally Posted by tandmsimmons View Post
    did you have the weep holes drilled?
    Old man in the mountains osbornk's Avatar
    Feb 2006
    Marion VA-In the middle of some of the best riding in the country.
    The life of clutches and brakes are very user dependent (just like a car or truck). For the most part, the life will be determined by where the bike is used and the riding habits of the user. You can take two identical bikes and one rider may wear out his clutch and/or brakes in 20,000 miles and the other may not wear them out in 100,000 miles.
    'You can say what you want about the South, but I almost never hear of anyone wanting to retire to the North.
    Let me know which cliff - there are some parts I might be able to use.
    Bigbadblue
    06 LT Clutch
    At 26K miles, I took the bike in for the dreaded $2000.00 clutch job. Bike is still under warranty, but the clutch is not covered, not even at 26000 miles? I will know in a week if it is an oil leak, good news, but that bothers me too. Anyway, the news will not be good, but hopefully not an impact on my wallet!
    Registered User rvb1019's Avatar
    Feb 2006
    Long Island, NY
    35K and still going!
    Knock Knock Knock
    Dec 2004
    Winnebago, Il
    LT Clutch life
    as osbornk stated there are to many variables to accurately say a clutch will last XX number of miles.
    On the 1200LT there are usually two resons the clutch fails.
    1) The Slave cylinder seals fail which then allows the DOT 4 brake fluid to pumped through the tranny input shaft and onto the clutch plates. This fluid is not compatable with the seal material on the tranny shafts so they may also start to leak.
    2) The O-Ring on engine output shaft starts to leak. This also allows oil to run down the shaft and into the clutch plates.
    2a) I personnaly do not believe that the real main seal engine seal leaking would contaminate the clutch unless it it fills the bell housing with oil. Do to design of the pressure plate housing it has a tendancy to fling the oil off before it would ever get to the clutch.
    Actual wearing out the clutch I think would takes lots of miles. Example my 85 K with 65K miles, the clutch was still with new tolerances when I replaced the leaking O-ring this spring.
    Roy
    Roy G.
    85 K100RT Ol Ruby "Gone but not forgotten"
    02 K1200LTC Hoss "Wrecked on 9/21/14"
    12 R1200RT
    Dec 2004
    Winnebago, Il
    I am with Paul G. on this. Since I have an LT could possibly use some parts also.
    Roy G.
    12 R1200RT
