Results 1 to 9 of 9
Thread: Teutonic QSL 1000 mile seats
    pwinick
    Anybody know how these seats mount on a /6. I bought seats but not brackets. The front seat has a fitting on the underside that looks like it slides on to a piece of pipe, which must have mounted on the bike somehow. If anyonehas any experience with these seats or, even better, has pictures of the bracket or how they mount, I'd appreciate hearing from you. Paul
    rabid reader dbrick's Avatar
    Santa Cruz CA
    pwinick,
    I don't have a clue, but I think you might reach a more knowledgable audience in the "airhead" forum rather than the "gear" forum.
    David Brick
    Santa Cruz CA
    2007 R1200R
    Focused kbasa's Avatar
    Moved to airheads.
    Carry on.
    Dave Swider
    Marin County, CA
    Aug 2003
    Marion,Ar.
    pwinick 1000 mile seat
    The pipe end of seat fits into the open oval end of bike frame, where the bmw cable lock normally slides up into. I think that's the answer. Barry
    Long Gone
    May 2004
    Quad Cities
    Paul,
    As Barry noted, the front "pipe" fits into the frame backbone opening below the rear of the tank. Since this is the same frame piece on which the tool kit box rests, you won't be able to use this box when using the QSL seat.
    The rear mount uses the same "Z" bracket as the front mount, but then has an L-bracket and curved piece intended to fit under the cross-frame member behind the battery. I reversed mine so the curved bracket fits on top of the frame; it's easier to remove the seat for working on the bike.
    I know that there was a passenger seat, too, but I never got one. I modified a luggage rack and installed a trunk where the passenger would normally be.
    A couple of hints:
    A sheepskin cover makes a good seat even better.
    If you're a larger guy, the seat may bottom (no pun intended) despite the robust springs. I inserted a tennis ball between the seat bottom and lower spring plate. BTW, this was about the same time as I installed air shocks. The shocks are long gone but the tennis ball is still there.
    Hogy
    pwinick, I have a /6 also, and I'd be very interested to see what that seat looks like.
    Where did you buy it? Is there a web site? A quick search didn't turn anything up.
    Hogy
    Long Gone
    May 2004
    Quad Cities
    Hogy,
    I got mine new in the mid-70's and I suspect the company no longer is in business. Google "Teutonic QSL" and you should find an ad for one on another BMW site - and that's it.
    If you're at all familiar with old farm tractors, think of their metal seats that were shaped to fit your butt. The Solo Saddle used a similarly-shaped fiberglass form covered with foam and naugahyde. As the name implied, it was intended for one rider (not too many naugas were killed).
    Hogy
    Chris, thanks for the reply. I need a new seat for my R90/6. I only ride solo. The cafe racer seats you see on ebay are cool, but won't look good on this bike. Are there any other solo seats you know of?
    Hogy
    Aug 2003
    Marion,Ar.
    reply to hoagie on teutonic seats
    You can still get the solo seats for /6 from BMW. Your local BMW dealer should be able to get you one. They are listed as police seats. Zelph makes reprodutions of the same seat, at a cheaper price. Do a Zelph search to find who sells them. Good luck.
