Results 1 to 8 of 8
Thread: Brown Side Stand Installation
    On the Road
    Sep 2007
    Riverside, CA
    Question Brown Side Stand Installation
    Hello all,
    I just received a Brown Side Stand today and it came with no installation instructions. I think I might be missing a few brain cells 'cause everything I've read about them says they're easy to install. I don't see the obvious mounting point(s) on my bike though. I have a 1975 R75/6. Anyone got pictures of how theirs is mounted, or a hint for me on where to put it (be nice ).
    Rod
    On the Road MAGOO's Avatar
    Jul 2003
    NW Central Ohio
    Undo the nut holding you exhaust hanger by your shifter, slide the hanger forward a few inches. Put the middle hole over the stud that you just removed the hanger from, install the nut loosely. Use the bolt and "shouldered" nut to attach the hanger to the front hole. Then tighten up every thing. Your stand should work properly.
    Doug Mc Gee
    Ice-Co Chair
    OH Airmarshal
    www.airheads.org
    ________________________
    Control your kids, not my guns
    the Wizard of Oz 26667's Avatar
    Jul 2006
    NW suburban chgo
    Thumbs up ez
    I had the same head-scratcher for awhile. But you use the rear motor mount, located under the shifter, and one of the muffler hangers. you may have to move the muffler hanger an inch or two. You can adjust the number of threads holding the sidestand to the motor mount by loosening the nut on the opposite side and tapping w a rubber mallet or the like.
    If you still have probs I can tak a pic tomorrow and post it tomorrow evening.
    good luck. But i bet you'll have a V-8 moment when you look again.
    We might as well walk. ~ Adam Guettel The Light In The Piazza
    used to own: 1982 R100T, 1984 R65, 1986K75C, 1997 R1100RT, R850R, K75S, 1978 R100RS... what was I thinking?
    Quote Originally Posted by magoo View Post
    Doug has it spot-on. You MAY need to loosen the nut on the OTHER side footpeg to give you more threads for the sidestand (that threaded piece you're attaching to runs to the other side of the bike and holds the engine in place). Even doing that, I still had JUUUST enough threads to get everything attached.
    One plus of the brown aside from it being pretty sturdy: It's a great warning device if you're leaning pretty far left; if you hear it scraping, your valve cover is painfully close to doing the same thing. DAMHIK.
    On the Road
    Sep 2007
    Riverside, CA
    Verify for me please.
    Is it the nut/bolt that's holding the exhaust AND the left foot peg? If so, that's what I thought, but it just seemed like too much stuff attached in one place.
    BMW Motorcycle Owners rdalland's Avatar
    May 2006
    of America
    Here's a close up of one installed:
    ride what you've got; enjoy the ride!
    Reid - Stone Ridge, NY - BMWMOA #69187 - Turbo Fluffy Motoclub - IBA #50182
    Minnesota Nice! braddog's Avatar
    Twin Cities - MN
    I didn't use the exhaust clamp/bolt...
    I used a P-clamp on the frame, which also required a bushing and a different bolt. This way, connectivity of the stand is on the frame all the way, and the exhaust is out of play.
    I felt like you, eosnut, but I was lucky in that my "S" already had a Brown on it when I bought it. So, I installed the one for my "RS" in a similar fashion. Check out the mod in the picture, see how a part of the stand was ground away to allow the shifter work correctly?
    Sorry, no pics tonight, maybe in a couple of days.
    Brad D. - Member #105766
    '77 R100RS - Black Beauty (big pipe, baby!)
    '94 R1100RS - Sylvia
    On the Road
    Sep 2007
    Riverside, CA
    Thanks!
    Thanks for all of your quick replies and for the pic rdalland. I think I got it now.
    Rod
