Results 1 to 2 of 2
Thread: Tank removal?
    Has the GS-Lust The_Veg's Avatar
    Sep 2003
    Atlanta 'burbs
    Tank removal?
    Very little plastic needs removing to get the tank off a K100RT. If memory serves, you only need to remove the left lower fairing panel, and then only so you can get to the fuel lines and electrical connetctions. A single 10mm bolt at the rear secures the tank. Remove that bolt and pull the tank rearward.
    If you do go the direct-battery route, don't forget a fuse holder in-line on the positive side!
    2012 R1200GS
    "If you can't fix it with a hammer, it's electrical." -somebody's dad
    Sep 2003
    Atlanta 'burbs
    OOPS!
    That was supposed to be a reply to the thread about installing the accessory jack on the K100RT...
    How about a little of that Immoderator Magic here?
    2012 R1200GS
