Results 1 to 15 of 17
Thread: Brake Failure R1200RT
    dlnoss
    I have a problem with my R1200RT.
    It has less than 9000 miles on it, I bought it with 7500 miles on it.
    For a while, the brake failure light would come on only sometimes when I would come to a stop. I could clear it by turning the key off then back on. It happened more and more often and, on the last ride, I couldn't get it to clear. The 'brake failure' light blinks about once per second.
    The fluid levels are okay.
    Does anyone have some suggestions for something I could look at or try? The nearest dealer isn't very near so I would like to avoid taking it in if possible.
    Any suggestions would be appreciated.
    -David
    Spring Lake NJ, USA
    David,
    Need more info. There are two different braking systems on R1200RT's.. need the year of your RT.
    dlnoss
    It's a 2006 model with ABS.
    First thought is to check the ABS sensor wire on the front wheel, left fork. It's easy for that wire to come loose from it's retainer, and if so it will rub on the brake disc.
    Charlie: IBA, AMA, MOA
    2006 BMW R1200RT
    Ride Pictures
    Ride Blog
    Quote Originally Posted by dlnoss View Post
    A 2006 with 9000 miles would seem to be an appropriate bike to take to the dealer and have them see if this isn't fixable under the warranty.
    dlnoss
    The wires going to the front sensor were rubbing on the brake disc. I soldered them back together but still have the problem. The manual says there are no fuses. I thought maybe the wires had shorted and blown a fuse. I'm goping to look again and see if maybe the wire damage was further up than what I fixed.
    -David
    Spring Lake NJ, USA
    David - Pauls response is right on.. the dealer should be taking care of this for you.
    You likely have the servo-assisted brakes - with these - the level in the visible fluid reserviors may appear fine - but these aren't going to reflect brake pad wear. There is a seperate set of reservoirs for the wheel circuits.
    If the wire wore through - I'd have the dealer replace the sensor.. and let them deal with the problem.
    dlnoss
    I will take it to a dealer. Wish there was still a dealer in Tulsa. Hopefully they will replace the sensor under warranty since I hacked away on the wire.
    Thanks for the help. I thought I had it whipped when I saw the messed up wire.
    -David
    R.I.
    -David
    On my '05, there was a recall (# 06V-164) on the Sensor Cable Routing, which addressed the "banjo bolt w/restrictor" part #34327702422 and the ABS sensor cable hitting the brake disk.
    Just looked at the recall notice and it says that it affects certain 06 models also.
    Recall Campain No. 06V-134 .....mention it to your dealer.
    Bill K.
    Foster,RI
    05R1200RT
    05 Vstrom
    Registered User Becky973's Avatar
    Jun 2007
    St. Charles IL
    Rear Brake switch
    I had about 10k miles on my 2005 R1200RT when I had brake failure lights. I still had residual brakes. My problem was the rear brake switch had become slightly loose and was permanently on. Having the brake on during initial startup caused the failure. The dealer realigned the switch in the housing and all ok since.
    Dick St. Charles IL
    On the Road
    Lubbock, Texas
    Brake Failure
    It is likely that the wiring problem set a error in the computer that can only be reset with the Dealers diagnostic box. You may have fixed the problem, but the error would still be there until electronically reset.
    Jim Davidson
    Lubbock, Texas
    dlnoss
    I got it back from the dealer today. They replaced the sensor/cable but it wasn't a warranty or recall item so it cost about $300 and I had the 6000 mile service done (another $320). The 6000 service had supposedly been done but I didn't have any documentation for it so I had them do it for the record. Whoever said "the only thing cheap on a BMW is the rider" was right but I really like it.
    While it was in the shop I rode a Sportster 1200 about 60 miles. Sure was nice getting back on the RT.
    Thanks again for the help.
    -David
    On the Road
    Nov 2007
    Denmark
    -David
    Hi David
    A friend of mine here in ice-cold Scandinavia Denmark had the same problem. It was caused by too little voltage on the battery. He bought himself a special charger he plug into the bike when leaving it on the centerstand in the carport and has not have the problem since
    JanDane
    bob1100rtc
    I don't understand why the repair wasn't under warranty. Was it because you attempted the repair your self? I would absolutely be flipping out if they gave me a $300 dollar bill for the repair!
    dlnoss
    I don't know why it wasn't covered. I bought it used, and the dealership where I bought it is sending me a check for what it 'should' have cost according to what they would have charged. The reason is that he thinks that maybe their service tech didn't make sure the cable was routed correctly after replacing the tires. (I bought new tires when I bought the bike.)
    I would have taken it back to them for the service but they are over three hours away compared to one hour. Riding three hours wouldn't have been bad (of course) but two six hour round trips with two vehicles wasn't very appealing.
    I think it's real decent of him to do what he's doing, particularly since I took it somewhere else to get it worked on.
    This was my first service experience with a BMW so I didn't know what to expect.
    What should the routine 6000 mile service cost?
    -David
