Page 82 of 202 FirstFirst ... 32 72 80 81 82 83 84 92 132 182 ... LastLast
Results 1,216 to 1,230 of 3023
Thread: Post a pic of your airhead
  1. #1216
    Northern Front Range, CO
    Quote Originally Posted by robertklee View Post
    Hey:
    What kind of seat is that???
    unless he was lying in his description, it's a Rick Mayer custom saddle
    http://www.rickmayercycle.com/
    Ride Safe, Ride Lots
  2. #1217
    Registered User robertklee's Avatar
    Mar 2006
    Tennessee
    Ha. Didn't see that...
    RKL
    "Leave the gun. Take the cannoli."
  3. #1218
    MJ'sRT
    Jul 2006
    w.mass - crossroads of NE
    R90s
    sunrise at the Quabbin
  4. #1219
    Registered User skiteach's Avatar
    Woodbury Ct
    Even the Alien likes it! (It's in the sky)
    '73 R75/5
    Never had a bad day skiing!
  5. #1220
    Registered User 6659's Avatar
    Jun 2005
    Woodstock, GA
    My new bike that I just picked up today. Needs a little work. Hope to have it on the road within the next year. Hasn't been run since 1982. Anybody have a short wheel base seat?
    77 R75/7
    78 R100/7
    93 R100R
  6. #1221
    Nov 2005
    Fairfax, VA
    Great find!
    I don't have a SWB seat (well, I do, but SWMBO would nail me with one of the .45's in a heartbeat if I ever took any parts off of her baby ).
    I wanted to mention that that bike looks very orignal, down to the old gold-patina air intake tubes. Be careful when cleaning them up -- the only ones available from BMW now are black. Light polishing with a dry cloth may be sufficient; you can go to a plastic polish if necessary, but test it on a hidden area first to verify it won't change the color.
    BTDT with the frame-up resto of a toaster -- a bit frustrating at times, but overall a great project -- I'd do it again in a NY minute. Enjoy!
  7. #1222
    Brain brainep's Avatar
    Feb 2008
    O'Fallon, IL (near St Louis)
    76 R90S Euro version
    My new to me 1976 R90S european version with 44,000 kilometers. Original paint (just a few blemishes), toolkit, manual, etc. Very nice survivor but will be ridden and not trailered. The bike was one of the 1976 S models to come out of Germany with the flush gas cap as the factory was transitioning to the /7 models (ref Fallon's R90S book pg 71).
    She joins my R75 with sidecar and R100 Classic in the garage. Yes I got it bad for airheads...need more room.
    Life is good!
    Brian "Brain" Kissinger
    76 R90/6
    98 R1200C
  8. #1223
    ROCKITDOC
    Twins
    Mine is a twin of yours. 44km when I got her, crash bars, Krauser mounts, DO.
  9. #1224
    Nov 2004
    Orlando, Fl.
    original paint
    Beautiful bike but I don't think the paint is original. The side covers (battery cover) should be solid color orange, not sunburst. Stunning example, none the less.
  10. #1225
    ROCKITDOC
    Quote Originally Posted by brainep View Post
    Life is good!
    Can you get on and ride from cold on your bike, or does it take 5-10 mins of warm-up? Mine starts right up from cold with some choke, but I need to let her sit and idle for 5-10 mins before I can ride off. After running and warm, start up and idle is fine, but not when cold. I am told the Del'Ortos are the reason and that not all of them had this issue.
    S
  11. #1226
    535IS
    Quote Originally Posted by mikeb921 View Post
    Given that each fogged panel had to be painted by hand, it would not surprise me in the least to find that some side panels got done this way at the factory.
  12. #1227
    Feb 2008
    Choke & sidecovers
    "Can you get on and ride from cold on your bike, or does it take 5-10 mins of warm-up? Mine starts right up from cold with some choke, but I need to let her sit and idle for 5-10 mins before I can ride off. After running and warm, start up and idle is fine, but not when cold. I am told the Del'Ortos are the reason and that not all of them had this issue."
    My R90S is a little cold natured, but not much different than the R75/6 or the R90/6 I believe. I start & warm it up a little with the choke on, then take it easy for a little while until it gets up to temp. But man does she run well & sounds good....a definite grin machine.
    As far as the side covers go....I am not 100% sure if they are original paint and really don't care. They look very nice. I do know you could line up a dozen R90S motorcycles in sequential factory numbers (and original paint) and each would look a little different & probably have some dissimilar parts on them...especially the 1976 models. That's part of the cool factor with these factory sport bikes...not one is the same as the next.
    Cheers
    76 R90/6
    98 R1200C
  13. #1228
    1_MTN_HIKER
    miles of smiles
    I imported this low miles RS mono-shock here to western Pennsylvania in early 2008 from the Canadian market. Thank you Mikey! Nice original, ridden condition. Everything works as it should. Bike looks like it's been protected from the elements when not ridden. Replaced the Valeo starter motor last year with an ND when the Valeo gave it up. That led to my review of the electronics and related bits and resulted in a decision for a new up-to-date ICU/ICM straight from BMW. I guess that was a good choice as the engine got immediately smoother and just ever so slightly more responsive to throttle inputs. However I swear that also resulted in quieter engine operation, which at first I wasn't sure I liked, but have grown to appreciate. While at it, I went with NGK BP7ES plugs and new plug wires. Performed general electronics connection cleaning and frame clean-up while in under the tank. Upgraded the battery from a fairly standard 25Amp BMW battery to a 30Amp Wesco which feels more responsive at startup and doesn't hurt on cold winter starts. Obtained a new battery retainer rail at same time just to make me feel it is buttoned up proper. Hinged oil filter cleaning BMW oil. Already made a decision to eventually open the front end and deal with Diode Board and go to the Omega Alternator... I just need an incentive to open it. You gotta appreciate that Rick at Motorrad Elektrik who advised on the ND starter and so forth. I only had one key for the ignition / fork lock and so I ordered both hinged and post steel blanks from the local BMW dealer, only to find no one in the city who could or would cut steel keys... and this IS the 'steel city'. Resolved by Bob's BMW when I was over that way in late winter on business. So enough already, I hope you enjoyed the post and write-up. The pic presented here is from the top of one of my favorite local ski slopes in the Laurel Highlands mountains, under the North Face chair lift.
  14. #1229
    Nov 2004
    Orlando, Fl.
    Cheers
    They really do look nice. No offence intended. I owned my R90S for 5 years back in the early to mid 90's and made it a point to learn all I could about them. I've seen several with sunburst side covers but none that left the factory that way. I've never seen Fallon's R90S book but does it show any with sunburst covers? I'm always willing to learn something new. As I said, stunning bike. Good luck with it. I know you'll enjoy it every time you fire it up.
    MB
  15. #1230
    ROCKITDOC
    They are unique. I just showed mine at a concours in Littleton, CO and the judges (although somewhat auto-centric) thought the carbs were aftermarket! IT's nice when one can educate the judges, ya no?
