Page 101 of 201 FirstFirst ... 51 91 99 100 101 102 103 111 151 ... LastLast
Results 1,501 to 1,515 of 3006
Thread: Post a pic of your airhead
  1. #1501
    Northern Front Range, CO
    Quote Originally Posted by therealbatman View Post
    ....I am in Blissville right now
    you have every right to be. well executed. looks timeless.
    Ride Safe, Ride Lots
  2. #1502
    Mike
    Sep 2009
    La Crosse, WI
    72 Toaster 75/5R
    Shes all original except for the horns which are off a Mercedes.
  3. #1503
    Atomic City Boxer 154048's Avatar
    Nov 2009
    Santa Fe, NM
    1980 R100RT taking a break in the mountains of Northern New Mexico.
    Steve in Santa Fe
    1980 R100RT
    96' Triumph Trophy
  4. #1504
    Registered User kwb210's Avatar
    Jul 2009
    Washington, the state
    1977 R100/7 w/ 74,000 on the clock
    my 1977 R100/7 w/ 74,000 on the clock. A pleasure to own and a pleasure to ride. I continually find myself dreaming up more reasons to take a ride. Even lame reasons sound good to me!
    1977 R100/7 1971.1972.1972.1973 R75/5
    1974 R90/6 multiple boxes
    Airhead Revival
    "Objects in the mirror appear to be losing" unk
  5. #1505
    Nov 2009
    Santa Fe, NM
    Aft End of the little Frigate...
    Steve in Santa Fe
    1980 R100RT
    96' Triumph Trophy
  6. #1506
    TGHSMITH
    steve does your front wheel have the webbing at the hub? if not you can get a new one, comes with new bearngs,, it was a recall..
  7. #1507
    535IS
    Quote Originally Posted by tghsmith View Post
    Damn, you're right. That sure looks like a pre-recall snowflake. Good eye.
  8. #1508
    Administrator 20774's Avatar
    Quote Originally Posted by 535is View Post
    Hmmm...is that "pre-recall" or "recall"? A pre-recall wheel would be just fine, right? Just sayin!...
  9. #1509
    Nov 2009
    Santa Fe, NM
    The wheel is indeed a non- buttressed unit. I have done a very close inspection of the spokes looking for any sign of cracking, but found none. Is there a specific place where the crack?
    Steve in Santa Fe
    1980 R100RT
    96' Triumph Trophy
  10. #1510
    TGHSMITH
    my 78 was in the recall, should be covered, cracks were to have happened were the spokes met the hub...
  11. #1511
    Nov 2009
    Santa Fe, NM
    How does one get a replacement wheel, at this late date? Is there a cost?
    Steve in Santa Fe
    1980 R100RT
    96' Triumph Trophy
  12. #1512
    TGHSMITH
    http://bmwmotorcycletech.info/19inchrecall.htm I found this... did a forum search
  13. #1513
    Nov 2009
    Santa Fe, NM
    Thanks, Jungle Cat....
    Steve in Santa Fe
    1980 R100RT
    96' Triumph Trophy
  14. #1514
    Nov 2009
    Santa Fe, NM
    My friend Pat's excellent R/ 75 with Hannigan in Taos, NM
    Steve in Santa Fe
    1980 R100RT
    96' Triumph Trophy
  15. #1515
    Pismo Beach, CA
    I just picked up a set of old Krausers for my LWB /5. There isn't more than about the thickness of a finger between the bottoms of the cases and the mufflers; not enough to even install Krauser Heat Shields.
    It looks like this set-up is about the same.... yes? No? I'm asking... . . And anyone else wo may want to chime in.
    Lew Morris
    1973 R75/5 - original owner
