Page 161 of 200 FirstFirst ... 61 111 151 159 160 161 162 163 171 ... LastLast
Results 2,401 to 2,415 of 2997
Thread: Post a pic of your airhead
  1. #2401
    Oct 2009
    Northern Cal
    Quote Originally Posted by bruche View Post
    bike is beautiful.what did you use to convert the front forks to dual disc?
    75-76 r90s, 77-80 r100s, 77-80 r100rs, 79-80 r100rt.
    www.boxermetal.com
    www.facebook.com/boxermetal
  2. #2402
    GOTTSTR
    Barn find 73 1/2 Toaster
    Hello...new guy with old Toaster, found it earlier this Summer sitting under a pine tree wrapped in a blue tarp, took it to the guys at Big Twin in Boise and Larry did a fantastic job of getting it back in running condition. Larry fabricated a device to clean the rust and dirt from the tank, it was saved!
    And thanks to Chris from Boxer Metal for pointing me to Siebenrock for the front hinge on the Polizei solo!
  3. #2403
    Oct 2009
    Northern Cal
    Beautiful!
    www.boxermetal.com
  4. #2404
    Quote Originally Posted by GotTstr View Post
    Wow, that's a beautiful bike !
    ________________________________________
    The early bird might get the worm, but the second mouse gets the cheese.
  5. #2405
    Pushrods forever.... lanordby1's Avatar
    Nov 2006
    Phoenix, AZ
    My old slash 5
    My 1973 swb R/75/5, that I've had since 1979. It was completely stock when I bought it other than Dunstall mufflers and a Wixom handlebar fairing. It's been through 2 ground up rebuilds, and up until recently I've done all the work myself.
    I figure I will own this bike until I die, which hopefully will be many years....LOL
    Lonnie
  6. #2406
    Nov 2006
    Phoenix, AZ
    more photos
    my 1973 R75/5
  7. #2407
    Nov 2006
    Phoenix, AZ
    more photos
    my R75/5
  8. #2408
    PSL, FL
    Quote Originally Posted by lanordby1 View Post
    my R75/5
    Ohhh myyy!
    Nice, got any shots of the instrument - triple tree area?
  9. #2409
    Nov 2006
    Phoenix, AZ
    This is about the best shot I have....
  10. #2410
    Pismo Beach, CA
    Judging by the presence of what appears to be a mechanical tach drive cable, is that the OEM /5 MotoMeter speedo/tach?
    Just curious, have you caught any flak from your local Gendarmes about the distance between your rear turn signals? Here in CA, I was informed, and it was suggested, that perhaps I might want to extend the stalks to 16" on-center (nice guy, a motor officer).
    Lew Morris
    1973 R75/5 - original owner
  11. #2411
    Nov 2006
    Phoenix, AZ
    Hi, you are right, that is a /5 speedo-tach unit, but because the 100S motor has no tach drive I've been using an aftermarket digital electronic tach. I've recently removed that electronic tach as I'm replacing the /5 speedo-tach unit with an Auto Meter digital speedo-tach, complete with GPS for speed monitoring.
    As for the shortened turn signal stalks, I've never had a problem in Arizona, nice catch though !
    Lonnie
  12. #2412
    May 2008
    B.P., MN
    Absolutely stunning, imaginative work, would like to see as much close detail as possible, post more, made my day, one of the best.
  13. #2413
    Pismo Beach, CA
    oops... that would be the speedometer drive cable I'm seeing.
    Lew Morris
  14. #2414
    harbor freight?
    Quote Originally Posted by rcockrum View Post
    Now the fun begins. Found a Velorex Sidecar I'm going to attach. Bike hadn't been started in a couple of years. Got in running in a couple of hours.
    Is that the harbor freight mc lift table? How do you like it?
  15. #2415
    Sheep Dog
    Apr 2007
    South Central Indiana
    It's worked just fine for several years now. Got the sidecar attached, so not too sure if I'll get as much use out of it. I've had an LT and a HD Ultra on it with no problem.
