Page 101 of 202 FirstFirst ... 51 91 99 100 101 102 103 111 151 201 ... LastLast
Results 1,501 to 1,515 of 3030
Thread: Post a pic of your airhead
  1. #1501
    Quote Originally Posted by therealbatman View Post
    ....I am in Blissville right now
    you have every right to be. well executed. looks timeless.
  2. #1502
    Mike
    Sep 2009
    La Crosse, WI
    72 Toaster 75/5R
    Shes all original except for the horns which are off a Mercedes.
  3. #1503
    Atomic City Boxer 154048's Avatar
    Nov 2009
    Santa Fe, NM
    1980 R100RT taking a break in the mountains of Northern New Mexico.
    Steve in Santa Fe
    1980 R100RT
    96' Triumph Trophy
  4. #1504
    Registered User kwb210's Avatar
    Jul 2009
    Washington, the state
    1977 R100/7 w/ 74,000 on the clock
    my 1977 R100/7 w/ 74,000 on the clock. A pleasure to own and a pleasure to ride. I continually find myself dreaming up more reasons to take a ride. Even lame reasons sound good to me!
    1977 R100/7 1971.1972.1972.1973 R75/5
    1974 R90/6 multiple boxes
    Airhead Revival
    "Objects in the mirror appear to be losing" unk
  5. #1505
    Nov 2009
    Santa Fe, NM
    Aft End of the little Frigate...
    Steve in Santa Fe
    1980 R100RT
    96' Triumph Trophy
  6. #1506
    TGHSMITH
    steve does your front wheel have the webbing at the hub? if not you can get a new one, comes with new bearngs,, it was a recall..
  7. #1507
    535IS
    Quote Originally Posted by tghsmith View Post
    Damn, you're right. That sure looks like a pre-recall snowflake. Good eye.
  8. #1508
    Quote Originally Posted by 535is View Post
    Hmmm...is that "pre-recall" or "recall"? A pre-recall wheel would be just fine, right? Just sayin!...
  9. #1509
    Nov 2009
    Santa Fe, NM
    The wheel is indeed a non- buttressed unit. I have done a very close inspection of the spokes looking for any sign of cracking, but found none. Is there a specific place where the crack?
    Steve in Santa Fe
    1980 R100RT
    96' Triumph Trophy
  10. #1510
    TGHSMITH
    my 78 was in the recall, should be covered, cracks were to have happened were the spokes met the hub...
  11. #1511
    Nov 2009
    Santa Fe, NM
    How does one get a replacement wheel, at this late date? Is there a cost?
    Steve in Santa Fe
    1980 R100RT
    96' Triumph Trophy
  12. #1512
    TGHSMITH
    http://bmwmotorcycletech.info/19inchrecall.htm I found this... did a forum search
  13. #1513
    Nov 2009
    Santa Fe, NM
    Thanks, Jungle Cat....
    Steve in Santa Fe
    1980 R100RT
    96' Triumph Trophy
  14. #1514
    Nov 2009
    Santa Fe, NM
    My friend Pat's excellent R/ 75 with Hannigan in Taos, NM
    Steve in Santa Fe
    1980 R100RT
    96' Triumph Trophy
  15. #1515
    Pismo Beach, CA
    I just picked up a set of old Krausers for my LWB /5. There isn't more than about the thickness of a finger between the bottoms of the cases and the mufflers; not enough to even install Krauser Heat Shields.
    It looks like this set-up is about the same.... yes? No? I'm asking... . . And anyone else wo may want to chime in.
    Lew Morris
    1973 R75/5 - original owner
    1963 Dnepr
