Post a pic of your Airhead
My anniversary edition
Here is my 83 Anniversary model Anyone have info on final drives? Mine shows 10 mph faster than GPS
What do you want to know?
If you look on the rearend near the flange that attaches to the swingarm there is a set of numbers like 33/11 or 32/10.
There is also a number at the bottom of the speedo face.
There is a chart that says what you should have.
they have to be correct to get the right speed reading.
But BMW Speedometers are known to be optimistic!
Getting ready for the Old School Spring Fling Rally. Blue Ridge Parkway here I come!
New picture of the Evil Bumblebee
Newly powdercoated front engine cover--not looking evil at the moment. After costing me $312, she is pretending to be good.
:whistle
Here is a pic of my R100CS that I've had for about 18 months. Just finished new brakes on it.
jw
The rotors are 300mm EBC rotors with spacers and 4 piston calipers with adapters to hold the calipers. The machining and layout was done by my friend James Banke from Banke Performance in Felton, CA. He specializes in this type of mod. The pads are FA, they grip well and are easier on the rotors than the HH type. New bearings and seals front and back. I cut the rear drum and put in Ferodo shoes. It has way more braking than stock. The master cylinder is the stock 15mm. Braided stainless lines, SJ upper triple tree, lower fork brace, and Progressive springs make up the rest of the front end. I've worked on it for the last 18 months and will continue to. The bike is one of my favorites.
jw
JW, your bike is elegant cool. I like your upgrades, keep us posted on any further developments and upgrades. Nice work so far.
Ebb & Flo
Recent sidecar "Bitsa" airhead to go with not so stock 71. Bitsa bike consists of /7 frame, R90 engine, R65 swingarm, 450 watt alternator, with a 70's Globe GS200 sidecar.
jw
what do you mean by cut the rear drum and install ferodo.
I have done some upgrades to my brakes, but still feel the back are just speed modulators
running ebc shoes in back
floating rotors, stainless lines, rebuilt calipers and masters hh pads
1985 R80rt
