Page 1 of 4 1 2 3 ... LastLast
Results 1 to 15 of 46
Thread: ear plugs
    Dec 2003
    Bethany, OK
    ear plugs
    I am trying to find a good ear plug to kill the wind noise on my
    R1150RT. I have tried some of the cheap foam ones and they don't work very well.
    I saw the EAR.inc add in the BMWON and their nice one is a
    little too pricey for me. Some local riders said that there is
    someone at a lot of the rallies that does sell them for $50.
    Can anyone give me a contact point on this vensor? Can
    anyone that has these molded plugs let me know how well
    they work?
    Are there any good ear plugs out there that are not quite so
    expensive?
    Thank you,
    Gerald
    State of Confusion
    What I would recommend doing is a couple of things. You may just want to go down to the local pharmacy and try some wax plugs. I personally don't like the fit but other people swear by them.
    I also purchased the Aerostich trial kit to see which ones I liked. That helped a lot cause then I went online and purchased in bulk.
    Another option is to go to a rally and see who is making plugs on site. I really like the plugs I got from Bob Weiss, who is a BMW rider and part of B Cubed.
    -=Brad
    Focused kbasa's Avatar
    I got a set of molded ones made at the local AMA races a few years ago and paid about $30. You might want to check with your local shooting store to see if they can help you. Alternatively, you might want to find the local hearing aid guys and ask them.
    There are all kinds of foam plugs and I've found the Hear-os fit my ears well. They're shaped like a little bullet with a flat end on them so you can pull them out. I don't like the ones with the sticks in them cuz they rub on my helmet and slowly drive me mad.
    Dave Swider
    Marin County, CA
    2014 R1200GSW Rich's Avatar
    Sep 2003
    Killdeer, ND
    Gerald,
    Just wondering if you are running with the stock windshield? If so, can it and get yourself a good aftermarket (I went with Cee Bailey's) windshield and the difference will be unbelievable. It sure was in my case. I still wear the cheap foam ear plugs, not out of necessity, but I like lots of quiet. Good luck.
    Dec 2003
    Bethany, OK
    ear plugs
    Thanks for all of the replies, I'll need to go to work now and see
    what fits me best.
    Rich,
    I am still running the stock windshield. I wear trifocals and for
    me to see in the stock mirrors I have to lower my eyes and
    head to the point I cannot see the road, thus I put some mirrors
    from the R1200CL on my bike so that I could still see the road
    when looking in the mirrors.
    I have been told that these mirrors will not clear some of the
    after market windshields when put in full lock position.
    These mirrors are the oval ones with the black plastic fronts on
    chrome mirrors. They are fairly low and cant out quickly so they
    do not stick up a lot.
    I still use the lower mirrors for a quick glance, but I do not have to
    take the time to focus since I have the handlebar mirrors too.
    Do you know of anyone who has used your windshield with the
    handlebar mirrors and did they clear in full lock position?
    thanks again to all,
    Gerald
    pdx
    Go to a local safety supply store. You'll find them in most bigger towns. The few I've been in have bins of all sorts of different earplugs. I tried a couple of each kind of the foam variety before finally settling in on the Howard Leight Max Lite. I then bought a box of 200 pair for $20. These plugs, aside from color and price, are virtually identical to Hearos.
    Registered User jgr451's Avatar
    Jul 2003
    Left Coast Canada
    As far as I know,the fellow who comes to the rallies to custom fit ear plugs actually sells and fits only the molding material.You can order the actual plugs from him by sending him the mould.It works well enough for a short time but breaks down rather quickly.
    I took the plunge and spent the big buck on custom made plugs,about $150 CDN.They work really well.They are a tight fit,not uncomfortable and they screen out wind noise,while still allowing me to hear conversations,and the engine/transmission noises.
    I dont know...hearing is nearly as important as seeing .I wouldn't skimp on it.A lot of shooters I know use the foam plugs with ear protector muffs-the double protection is good-but there are a lot of hearing impaired people out there who didn't protect their hearing soon enough.
    Sep 2003
    Killdeer, ND
    Re: ear plugs
    Gerald
    I can't help you there, Gerald, but maybe someone else will see this and add there eperiences with what you are describing. I guess you could take a digital picture of your setup and then email it to your choice of aftermarket supplier of windshields and they could sure help you out. I don't know how tall you are but I am 5'10" and the Cee Bailey sure did the trick for me. I am sure others out there are just as good. If you want to know the design I went with (there are several), email me and I will fill you in on the details. Or look for other members recommendations on what to buy. The stock shield just doesn't do the job, in my opinion.
    dlearl476
    I now have three sets of custom molded plugs. 2 plugs and one in-ear monitor (All from EAR, Inc.). Custom molds are great, but to be perfectly honest, I ride with my Howard Leight "Leight Sleepers" the most. These are H-L version of the SOFT foam sold by many vendors, but the actually have the MOST attenuation of any of them (30db). They are flourescent yellow and pink, hard to miss in a tankbag. They are readily available at any Walgreens and probably any other phamacy. Comes in handy when you lose one at a gas stop in a stiff wind. But they come in packs of 12 with a handy tank bag-able container.
    I only use my in-ears if I want to listen to music.
    HEY! How did I become a "rally rat'? I didn't do that, I'll change it after the 200.
    pdx
    Yep.
    That's why I gave up on custom molded plugs. When I tried out a pair a few years ago, their NRR was markedly lower than that of the foam plugs.
    Having said that, Brad recently told me that the molded plugs have gotten better in recent years. I might have to give them another try. It's just hard for me to rationalize trying them again when the el cheapo foam plugs are all of 10 cents a pair.
    State of Confusion
    I use both. For me, the custom molded work better but only use on longer rides. I use the disposables for the local rides where I know I will be taking the plugs in and out a lot, and losing them a lot.
    The biggest complaint I have is trying to find in helmet speakers that are thin enough not to be painful and squish my head.
    -=Brad
    bmwmon
    Gerald, Here is the sure fix, Go to your local hearing center and get professional molded ear plugs made and for a few bucks more you can have them install tiny little speakers for your music as well. I paid $80 dollars for basic plugs "The sure fix" and I ride an RT
    bmwmon@earthlink.net
    ABC,AMA(LIFE),MOA,RA,IBMW MANICMECHANIC's Avatar
    May 2003
    Manitowoc, Wisconsin
    Consider
    From personal experience, I used the disposable plugs for a while, still use them at work on occasion. However, on a long tour, in warmer weather, after a couple days the inside of my ears would get irritated, making for an aggravating ride. So I went for the custom plugs. Found a vendor at one of the bike shows made them right there, came back in an hour and they were finished. Also ordered up a set of the molded speakers, which seem to work well as plugs, too. Yes they are a little pricey, but I don't have the earritation any more.
    F.O.G.Rider, Rounder #6,
    Ambassador
    BMWRA Wisconsin Region Rep
    MOA Biergarten co-chair
    Rally Rat YB in IN's Avatar
    Bloomington, Indiana
    I use the Howard Leight plugs as well. I find that they work just as well as anything else on the market. My dad gets them from his factory job for free.
    pdx
    I should also add:
    Since they only cost 10 cents a pair, I discard them as soon as they're remotely dirty. Why stick something nasty in your ear?
