deilenberger
A bozo on the bus
Correct.ddervin said:Don-
Thanks for the reply. I'll post here instead of email you directly for the benefit of others.
My bike has 81,900+ miles on it, and I have kept meticulous records on it for the past 17 years that I have owned it. I'm the second owner, but it only had 2718 miles on it when I bought it as a bank repo in 1987.
I'm not sure what you mean by the "FYK", but I have religiously had the clutch spline lubed every 10,000 miles. Since I have lately started to get confused by dealers, I haven' t had the clutch spline lubed since about 13,000 miles ago by a dealer in southern Ohio I trust. My confusion from varying dealers about the maintenance schedule for this service is why I am looking for "definitive" answers about this.
However, I am not sure about if the folks ever did the rear drive splines at the same time, because they never asked me if I wanted it done, and I never asked them to do it because I always thought it was the clutch spline that was the big thing to do- I never new about the drive splines!
Yikes!
However, four years and about 9000 miles ago ( I don't ride it all the time anymore, I love it so much I'm trying more to "preserve" it throughout my lifetime!) the bearings in my final drive blew (don't know the cause of that because I ALWAYS replace the gear oil in it at the start of every "season" every year), and when I personally replaced the final drive, I greased that rear drive spline, because my basic knowledge of mechanical stuff told me it was "the thing to do". I remember clearly it already had what I thought was a "decent" amount of grease on it, but I cleaned both the spline and the "female", part of the new final drive, and greased them both. I used fresh "regular" grease I had lying around, which is definately not Honda Moly60.
I will immediately pull the final drive, find some Honda Moly60, and clean and grease everything again.
To clarify, I'd like to reiterate what you are telling me for you to verify I have this right.
1. Find and buy HondaMoly60 (probably at a Honda dealer- duh...), and pull the final drive and clean and grease the rear drive spline. You recommend this should be done every 10,000 miles.
Correct again - although doing the front really isn't necessary, do it so you know it's done. Then forgettaboutit.2. Alternatively, the shaft could be pryed out in it's entirety, both spline ends cleaned and greased with Honda Moly60, and put back in by rotating and aligning, and whacking it back in with a leather (or rubber?) mallet. Again, you recommend this entire service is to be done every 10,000 miles (and sounds easy enough for me to do).
Correct again. Since we don't know what grease the dealer used - I'd suggest getting it done. Most dealers are still using up their stock of BMW#10 grease - which IMHO (and that of a lot of other people) was a mistake on the part of BMW (there is a lot more to the story.. but I won't bring it here..)3. You recommend the clutch spline be lubed every 20,000 to 25,000 miles with Honda Moly60. This I REALLY, REALLY WISH I could do myself, but I just don't have the setup to hold the bike up. I HATE having to pay around $375.00 to get it done, and would MUCH rather do it myself so I KNOW it's done right (paranoid), but I think it's out of my personal mechanical and tool ability.
It's usually the rubber O ring under the nut on the clutch basket. Usually when that is replaced - since you're almost there - people replace the main engine seal. Might add $100 to the bill for the dealer to do it... it doesn't take all that long when it's apart.----------------
I have one more question;
There is a "weep" hole on the bottom of the tranny that gets about 6 or 8 drops of oil out of it now on every ride.
1. Is this a "main seal" between the trans and engine that is letting loose?
Yes - see above2. Could it be replaced during a clutch spline lube since the trans would be out? I realize the clutch would have to be disassembled, but hey, having it torn down that far already might help.
THANK YOU VERY MUCH!
DSD
