Results 1 to 15 of 27
Thread: Numb Hands (Moved to correct forum..)
    Registered User gboyvin's Avatar
    Sep 2006
    Omaha, Nebraska
    I have had my 1200 RT for 6 months have have tried everything from hand grip covers to thick gloves in an effort to eliminate my right hand from going numb on rides. I have had several different bikes in the past (primarily HD) and I have never experienced this problem. My local delaer is at a loss for remedies, so I'm looking for ideas.
    Registered User LENRT1200ST's Avatar
    May 2006
    Sanderville, GA
    Quote Originally Posted by gboyvin View Post
    I have had my 1200 RT for 6 months have have tried everything from hand grip covers to thick gloves in an effort to eliminate my right hand from going numb on rides. I have had several different bikes in the past (primarily HD) and I have never experienced this problem. My local delaer is at a loss for remedies, so I'm look for ideas.
    This may sound really simple, but I have found that a more relaxed grip in the bars will go a long way toward easing this problem. Light touch, better control too!
    Len
    Registered User 17butler's Avatar
    Northeast Iowa
    Numb Hands help
    I use Throttle Rockers on both grips. These help me not to grip too tight. Then I scoot up in the seat for less weight on my hands. Plus, I use the Throttlemeister as much as possible. With my minimum carpel tunnel this all helps. Try it all!
    R1150RS
    '02 1150 RT cardno7's Avatar
    Apr 2007
    Louisville, Kentucky
    if you are uneder 5'11", you may try bar backs or handle bar risers; worked great on my 1150rt
    ltljohn LTLJOHN's Avatar
    Jun 2005
    Haycock, PA
    I sometimes have the same problem. I loosen my grip and also move my elbow in closer to my body, not sure why this works but you can feel the difference immediately
    USN Retired
    '02 R1150 RT
    Just north of Seattle, WA
    Watch how closely your clothing fits around your wrist. A tight strap on a glove or a tight cuff on a riding suit/jacket will cut off blood flow to your hand as surely as a tourniquet. If you're left-handed, a watch worn on the right wrist can get squeezed between your wrist and the fabric of your clothing, further constricting the blood flow into your hand.
    Loosen up the restricting clothing around your wrist and let that blood flow into your hands!
    Seattle, WA
    2012 R1200GSA
    2002 R1150RT-P
    1992 K75S sold
    Aug 2004
    I find the single most important thing in keeping my hands comfortable is the bend at the wrist. The straighter it is, the more comfortable. So I start off by gripping way forward on the grip so that when twisting the throttle my wrist is a straight line from my forearm to hand.
    2-up and havin' fun sugarhillctd's Avatar
    Oct 2007
    Just above the Notch, NH
    Quote Originally Posted by ltljohn View Post
    Excellent suggestion- and here is why it does work- Moving your elbows closer to your body has the effect of causing the muscles in your shoulders to relax.
    Quite a few of the people that I see in my office have the same problem, but get these symptoms when driving a car. I have them try to hold the steering wheel further down towards the 4/5 o'clock and 7/8 o'clock position. This has the effect of allowing their shoulders to drop and relax.
    "Bar-backs" may also help, as may stretching your shoulders before AND AFTER you ride.
    These type of altered sensations are often attributed to a neurological cause but are many times due to muscular tightness- try "Googling" Trigger Points or look at this particular link:
    http://www.triggerpointbook.com/neuropat.htm
    Good luck.
    John
    John & Cathy
    '92 K100RS (gone- '04 R1100S Boxer Cup)
    '12 Suzuki DRZ400
    ("kid's" bikes) '02 Kaw ZX6R- Jen's '07 Duc 800ss- Johnnie's
    Sep 2006
    Omaha, Nebraska
    Thumbs up Thanks
    Thanks for the great feedback, I will certainly try all the suggestions.
    Jul 2006
    Fairfax, VA
    The 1" up and 1" back risers from Cycle Concepts cured a numbness in my right index finger.
    Mark
    MARTYW
    I have the solution for you!
    Try this website www.qwinerveprotector.com
    I have carpal tunnel, and after a 1/2 hour on a bike, I'm locking the throttle on, so I can shake the tingling out of my hands. I bought a pair of Qwi gloves at the Wisconsin rally, and rode 400 miles the next day with NO numbness. What a great feeling!
    These gloves have pads in the palms that protect the "ulnar nerve" that runs through there. They look just like regular riding gloves, with two small pads on the heel of your hand. It's so simple, and so effective.
    I bought the fingerless version with the spandex back, which are very comfortable. I will buy a full leather set this fall for colder weather riding.
    Best of luck
    -Marty
    Sorry if I've posted this information twice. I hit the submit button once, and didn't see that it got posted, so I wrote it again. The original may show up. My mom always said, if it's worth saying, it's worth repeating.
    Jun 2007
    Brownsburg, IN
    I had the same problem on my first "long" ride on my RT. I relaxed my grip and used the outer part of my palm to hold the throttle verses the part by my thumb. Worked like a charm.
    Old man in the mountains osbornk's Avatar
    Feb 2006
    Marion VA-In the middle of some of the best riding in the country.
    I find myself leaning on my hands and it makes them go numb. If I concentrate on keeping my weight off my hands, it helps a lot and loosening my grip also helps. The throttle rocker helps on my airhead but the cruise on my CLC is worth its weight in gold. Set the cruise for about 1/2 a minute and everything clears up for a while.
    'You can say what you want about the South, but I almost never hear of anyone wanting to retire to the North.
    mlucas1
    Cool Using the mouse
    My right hand gets very tired when I ride. I ordered a Throttlemeister and hope to get it today. I sure hope it helps. Like many of you I spend my day at a computer using the mouse and also have a sore hand from that. Combine that with riding and you have a sore hand. My chiropractor worked on my hand and that has seemed to help some but I'm really looking forward to the Throttlemeister.
    Mark
    MARTYW
    It sounds like a bunch of you guys would benefit from the Qwi gloves. Most of the symptoms you are describing are attributable to an irritated bundle of nerves. I'd suggest any of you to try them. Then you wouldn't have to adjust your riding posture, or worry about which part of your hand you hold the throttle with. You can grip it as tightly as you like, for as long as you like. If these gloves could make such a difference for me, with a fairly good case of carpal tunnel, I believe they could make a difference for just about anybody who has tingling in the hands.
    I do not represent this company in any way, I just want to share my good fortune with somebody who has the same problem I had.
