Results 1 to 11 of 11
Thread: Leap Year Ride
    State of Confusion
    Talking Leap Year Ride
    Today was a warm enough day to go for a nice long ride. 150 Miles at 50 Miles an hour on average.
    Got the ultimate wave from a Semi truck, just happened to be one of the Harley Fleet. A wave and honk from across the road.
    I have found the drawback from hydrating tooooooo much. A few more stops than I had planned.
    -=Brad
    El Dookey loves to ride. 99007's Avatar
    Aug 2003
    Ada, MI (outside Grand Rapids)
    Always with the questions...
    How else am I gonna learn nothin'?
    Mr. B Squared - What is "the ultimate wave"?
    One with money? One with booze? One with exposed flesh?
    (Tom Tom Club rocks - have you heard the one they put out last year???)
    State of Confusion
    Ultimate Wave cause
    Loud Honk from the airhorn.
    Shout and wave out the window about the ears and riding.
    Just right place at right time.
    -=Brad
    pdx
    So how were the electrics?
    State of Confusion
    Unhappy
    Didn't use any electrics.
    I have still not wired in the harness to the battery yet. The accessory socket is only rated for 4Amps and this takes at least 6Amps.
    Since I was gone most of last week, not a whole lot of time.
    Today I decided to ride instead of wire. So I used the high tech layering method.
    Didn't do too bad. Had to stop about halfway through and put on a sweatshirt to add a layer.
    -=Brad
    pdx
    I know this was already talked about, but is the actual fuse only rated to 4 amps? Someone else probably knows better, but I remember the wiring for the accessory sockets being very simple.
    State of Confusion
    Yup already talked about and confirmed. Even talked with my local dealer and they were surprised. They are actually going to contact BMW as it will also not work with the BMW 70W electric vest.
    -=Brad
    Focused kbasa's Avatar
    Sounds like a good excuse to add a fuse block and reroute the accessory plug wiring.
    Couldn't you run a lead straight from the battery to the fuse block and then reroute the wiring for the accessory plugs to the block?
    Dave Swider
    Marin County, CA
    State of Confusion
    My current plan is to run the harness straight from the battery to one of the two sockets under the seat. That way I have a 10Amp and a 4Amp socket set.
    Supposed to be thunderstorming and about freezing tomorrow so I think we can all guess what I will be doing when I get back from the office.
    -=Brad
    CustomSarge
    Question 4 Amps?
    Most all bike wiring is at least 20 AWG, with a lot of 18 & 16. 18 AWG will take 10 amps, I'd put 7 amps through 20 AWG without a blink. I'd just rate the fuse according to AWG. Ampacities are listed in the NEC (Nat'l Electrical Code) book & other places. I can't see a 4 amp fuse to an accessory point, unless it's just for diagnostic equ power.
    Hey, we had one of those, a Leap Year Ride that is.
    We had some questionable riding surfaces.
    Some no-question-we-shouldn't-be-riding-on-this surfaces (pic snapped after I picked the bike up ).
    Some fast gravel.
    Some formation flying.
    And finally some fast paved swervery.
    About 250 miles in total, and not a bad way to use an extra day.
