Results 1 to 4 of 4
Thread: cyl head re-torque
    Dec 2004
    Wales Ma.
    cyl head re-torque
    does any one know if the cyl head re-torque @ 600 mi. is the same as on an 1150 .. 15ft/lbs then 90deg + 90deg and 30ft/lbs on the8mm bolt ???
    Has the GS-Lust The_Veg's Avatar
    Sep 2003
    Atlanta 'burbs
    This may help:
    Torque Table
    2012 R1200GS
    "If you can't fix it with a hammer, it's electrical." -somebody's dad
    Dec 2004
    Wales Ma.
    Just what I needed , Thanx
    Mar 2004
    Alexandria, VA
    These are 20nm if you have to loosen them, try to find THEM in the manual or torque chart. I had a heck of a time.
    The head bolts for retorque are 20nm plus 180 degrees.
    The T-45 Torx is 40nm
    This is slightly different than the initial torque of a new head gasket.
    Jim
