Results 1 to 7 of 7
Thread: Battery Chargers
    fishhead
    Battery Chargers
    I have an 1150 GS. Since the battery is a pain in the sitting bones to get to, is it possible to hook up a battery charger (Battery Tender) thru the accessory plug? If so, where can I get a plug to make it work? Thanks.
    SNOONE
    Battery Tender sells a unit that plugs right in. Most dealerships stock them
    Focused kbasa's Avatar
    Yup. Just plug it right in.
    Dave Swider
    Marin County, CA
    CustomSarge
    Here's a design we'll never see from a company. Use a modern glass-mat sealed battery & lay it on its' side, top towards bike rear. Easy access to terminals & removal by pulling the seat. Don't know if any stock tank would straddle it. I'll try this on the R11HR when the liquid one dies.
    Registered User jhelming's Avatar
    Apr 2004
    Ledyard, CT
    Question Battery Tender alternative?
    Anybody have any experience with the Harbor Freight $14.99 'Automatic Battery Float Charger?' Per the catalog description, it appears to function exactly like the well-known brand, but for less than half the price.
    http://www.harborfreight.com, item #42292-ORAH
    John H.
    On the Road kmEatr's Avatar
    Hamilton, Ontario, Canada
    i just put a new gel battery into my 97rt.....a real gel, not the glass type. the battery tender jr. was the only one i could find around that deffinetly would not over voltage while charging. i plug it into the acces. socket on the dash with the provided adapter.....it also came with hard mounts (6 inch direct mounted terminal leads) and the regular pinch battery leads.
    DZIMBRIC
    Overcharging Gel Batteries
    There is an excellent article in Arpil? BMWMOA. Make sure the charger stays below 14.4 volts.
