Results 1 to 15 of 21
Thread: movin' off centerstand '03 K1200LT
    Loading the Bike iraon2r's Avatar
    Jan 2004
    Howell, Mi
    Have 03 K1200LTC, am 5'8", 180#, and INSEAM challenged. I don't have lowered seat (yet). Am looking 4 different methods to get bike off center stand. I'm tired of asking wife for push and her laughing. Tried standing on ground and rocking it 1 time, and the bike leaned up against me, into the metal storage racks, and I've got a scratch to prove it. Hate those slow motion lay overs.
    Registered User jgr451's Avatar
    Jul 2003
    Left Coast Canada
    Get a Reynolds ride off-less lift,less camming action.You literally ride off it.A bit scary on slippery uneven ground or gravel.
    Jan 2004
    Howell, Mi
    Am not familiar with Reynolds Ride-Off. Didn't have this problem with my RT. Do you have a web site add. for them ?
    Jul 2003
    Left Coast Canada
    Jan 2004
    Howell, Mi
    Thanks. I went to site, and requested info and pic.
    Spring Lake NJ, USA
    Re: movin' off centerstand
    I never ride off the centerstand.. I just put the sidestand down and lift the bike off the centerstand THEN get on it and ride away. And I never use the centerstand on the road - it gets used in my garage just to save space.
    The sidestand is MUCH more stable in most conditions - makes for a much larger triangular footprint for the bike.
    I've never understood the BMW rider's fanatical use of the centerstand. For me - it's for working on the bike (removing wheels..) or for use in ideal conditions where the space is limited (my garage..) But - mebbe it's just me.
    Dec 2003
    Cleveland TN.
    Lightbulb center stand use
    I'm 5' 9" and 170lbs and when I get my bike off the centerstand I always have the sidestand down and nudge the bike off to let it come to rest on the sidestand. I also hardly ever use the centerstand on the road (garage use mostly). I will never try riding it off the stand. The only drawback to sidestand use is that your bike will smoke badly when parked on the sidestand. I have found that when you stop your ride before you put your sidestand down that if you will lean your bike to the right for about 20 to 30 seconds before getting off the bike that upon startup you will not have any smoking at all. Something to do with oil draining down into the sump or whatever. It does work to eliminate smoke on startup.
    Spring Lake NJ, USA
    Re: center stand use
    Man after my own heart.. and 10 seconds works just fine to eliminate the smoke on startup. I don't even lean it to the right (short inseam) - I just keep it straight upright with my tippy-toes. Nice thing about having a wired in Garmin - you can watch the seconds count down from 30 when the unit is powered off
    Dec 2003
    Cleveland TN.
    I'm with ya
    I was a little on the conservative side with 20 to 30 seconds--I'm sure 10 secs will do upright. I got to get me one of those Garmin things!!
    Gary99
    I am not particularly tall, but do not have any problem getting the bike off the center stand. Just lunge forward, with the sidestand up, and in neutral, and it rolls right off. Hardly travels a foot. I only use it at home, but it is the only way to get accurate and consistent fluid levels, plus makes it easier to check tire pressures, or wash the bike. The bike still deposits black soot on the floor of the garage, and blows smoke, so that is not a consideration. I used to not like using the centerstand because I had trouble putting it up on the stand. Since I learned the technique for putting it up, it is a non issue.
    v8dave
    Originally posted by LTOwner
    . . . I used to not like using the centerstand because I had trouble putting it up on the stand. Since I learned the technique for putting it up, it is a non issue.
    I'm a new member and this may have been covered previously, but, what is "the technique?"
    I've recently acquired an extremely low mileage '87 K100. My technique to put it on the centerstand is to: grasp lift handle under the seat with my right hand, place left hand on the left handle bar grip, place the ball of my right foot on the center stand, and then snap the bike up and back while placing most of my body weight on the center stand foot lever. It comes up, but not exactly easily.
    BRIENP
    Angry Center stand
    Whoa, I just read your message exactly one day after buying a K75. How the HECK do you get that thing up on a center stand?
    Yours might be lowered....
    If your bike has been lowered as my '92K75RT is, it makes the business of getting it up on the centerstand pretty difficult except on the lawn where the stand sinks in about a half inch. Mine has been lowered by 3/4 inches, which makes the lift to put it on the centerstand a lot harder, so I placed a couple of 3/4inch plywood squares in the garage with a gap between. I park the bike with the front and rear wheels on the plywood squares and the centerstand then is easy to use as it's 3/4inch lower than the wheels. Try it......you'll like it!
    Apr 2008
    SW Ohio
    Quote Originally Posted by wndsrfr View Post
    Good idea, just remember to creep up on the plywood SLOWLY. I once tried parking on a
    square of carpet in my garage, hit the front brake, wheel stopped, but my momentum
    transferred to carpet with lousy coefficient of friction to garage floor. Managed to
    keep it up, but it was a WTF! OH SH** GODDAMITALLTOHE** kind of special moment.
    I forgot all about that until reading your post. Thanks for the memories!
    RK Ryder
    London, Ontario
    Quote Originally Posted by iraon2r View Post
    I thought that the K1200LT had a motorized centre stand. If so, could you not just lower it to the side stand? If not, (and your bike is much heavier than my K100), why not have a couple of buddies spot you (one on either side) while you practise rocking the bike off of the centre stand and lowering it to the side stand. Do keep it in gear while rocking off the centre stand. I had gotten out of the habit of the rock and catch technique and was quite apprehensive of trying it this summer. I had one of my sons on the right side to catch the the bike if it got away from me. It isn't it that hard once you do it a few times, but be certain to have the handle bars aimed slightly left (did it once with them aimed right and my 145#s wasn't enough to keep it from going, going, gone right.)
    Paul
    Knights of the Roundel #333
