How do I post a picture? Try 2mb or less sizing
What is the error
What are the symptoms? Does the image not show up, just shows up as a
All that shows up is the message, and there isn't even a hint that I tried to attach something. I am going to try to attach my avatar as an attachment to this message, and you will see what I mean. It just won't be there.
I am using windows. I just tried attaching my avatar like I said and nothing.... I do the browse thing, find my avatar that is saved, and pick it, it shows up in the attach file space, and then I "submit reply", but when taken back to post, it just isn't there. Thanks for the assistance, and whatever you come up with.
WHAT THE HAY!
Something changed since yesterday. I'm just glad it's back to working, it looks like BB was having trouble too. Hmmmmm.
Multiple pics
How do I insert multiple pics, and text, like the big guys do with trip reports (to wit: Nye's Daytona report)?
Re: Multiple pics
You'll need a place on the web to host your pictures. A bunch of us are using smugmug.com ($20 a year, unlimited albums) to host the photos. When you're putting your message together, you click the IMG button and past a link to the picture in the box. I think there's a thread in the How Do I... forum that talks about how to do that.
It's definitely easier to do than attaching photos. If you take a lot of digipics like I do, the hosting is a huge bargain.
I see others have had troubles?
This is my last test for the night. I have the recommended program, pic is resized properly, but only the text coming on board? If not tonight..tomorrow
Good morning - will try again!!
I seem to be having the same trouble Rich had? Windows in use, resized with suggested program, I don't preview....appears to be taking pic when I push "submit"...slowly takes the thread:
-yet, my thank you for submitting comes through, with no pic!...just text.
-so here goes another try...if a pic does not appear, I will await further thought from more qualified folks. THANKS SO MUCH
Just checking to see if it works right now
and if it does, it should work for you.
Folks are so helpful! - Will try again, now
Grateful for all the help..I have made one modest change, not sure it will affect the outcome:
-using windows 98, Irfanview, reducing to 3oo width, 72 DPI
-after the text, I add the picture under "attached file", I DO NOT PREVIEW,
-as I submit , it appears to be taking the "whole effort", but as above, only the text comes thru
-yes, in early takes...pic was rejected outright becasue it was too large (that does not happen anymore since downsizing)..I get a Thank you for submitting the thread.
Here goes! If it does not take - will check back this evening.
Thanks. Ray
Re: Folks are so helpful! - Will try again, now
Thanks. Ray
Try saving them as .jpg files and see if that helps. .bmp isn't usually viewable in a browser, I believe.
Re: Re: Folks are so helpful! - Will try again, now
Not only are bitmap (.bmp) files not viewable in browsers, they are MUCH larger than images saved as jpegs.
