Results 1 to 2 of 2
Thread: Motolights on F800ST
    The F800ST presents a few dimensional challenges for caliper mounting Motolights. After lots of trial-and-error engineering, here is what‘«÷s required for the F800ST caliper mount Motolight installation as shown:
    (Motolight parts)
    10-695 Caliper Mount Spacer Block Set
    10x1.25x60mm socket head zinc plated 12.9
    10mm lock washer
    The 10-695 spacer block has a 25mm offset and the stock BMW caliper bolt is 35mm, therefore a 60mm bolt is required. Please note that I did not use the lock washer because using it requires an additional 2-3mms bolt length (63mm?) to fully penetrate the caliper. I believe with proper torque, the clamping force should be sufficient. If you purchase a kit online, confirm it includes these parts.
    More pics: http://www.pbase.com/bricciphoto/motolights
    Ben Ricci
    Rides & Drives: '07 BMW F800ST Low, '07 Porsche Cayman, '06 VW Jetta TDI & '05 BMW R1200ST
    Riding where it's hot! AZ-J's Avatar
    Mar 2007
    Scottsdale, AZ
    Very nice, indeed, and thanks for the particular instructions.
    My bike shown here
    Jordan M, MOA #24434
    My Blog
