Results 1 to 3 of 3
Thread: R1200RT cold running problem
    May 2004
    St.Bruno, Quebec
    My 07 R1200RT with 11500 kms has a minor problem when I start the engine for the first time in the morning (engine is cold). It starts and idles fine. But if I try to open the throttle, it will die unless I give it very small amounts of throttle. If I shut it down and restart it, everything is fine and it responds normally to throttle openings. Is this normal behavior?
    Johnv
    WDaigle
    I have an 06 R1200RT with 29000 miles on it. Mine has never done that. Have your dealer check it out, may just be something minor.
    Sheboygan, WI
    Exclamation My 2 cts Worth
    Ditto for my '05 R1200RT. No problems with cold morning starts. See dealer!
