Results 1 to 6 of 6
Thread: GS & RT grips- interchangeable?
    Has the GS-Lust The_Veg's Avatar
    Sep 2003
    Atlanta 'burbs
    OK here's a good one.
    I really like the grooved-style handgrips that late-model RT's (and early K-Bikes) use, and I'd like to put them on my GS (the grips on which I can live with but don't really like). My GS has the heated grips, which as far as I can tell have the rubber grip moulded onto the heating element.
    I've seen the style of rubber grip that I like on R1200RT's, so what I want to know is if the RT grips are compatible with the GS- do they physically fit, and do the heat-elements connect?
    If nobody knows, then maybe someone with an RT could be kind enough to post pics of how their grips come apart so I can figure out the answer.
    2012 R1200GS
    "If you can't fix it with a hammer, it's electrical." -somebody's dad
    Sep 2006
    having both, I am also curious...I have changed the rubber on the RT and they were like older R's...element was wrapped on under the grips... and came off easily
    The GS grips are very stiff/hard in comparison and I would prefer the RT style also...
    I will look at diffs tonite to see if someone doesn't weigh in
    looking at A&S's microfiche the grips do seem to be grip & element in one
    http://www.ascycles.com/Illustrated_..._frameset.html
    Steve Henson
    Sep 2003
    Atlanta 'burbs
    Yeah but those fiches don't give much visual detail.
    2012 R1200GS
    Sep 2006
    the GS appears to be an all in one unit still... on RealOEM site: http://www.realoem.com/bmw/
    this 'fiche shows a integrated looking grip:
    http://www.realoem.com/bmw/showparts...05&hg=32&fg=15
    here is the R series fiche: grip and element are seperated...the RT was the same
    http://www.realoem.com/bmw/showparts...49&hg=32&fg=15
    I am thinking going to local bicycle shop and getting some padded bar tape...the heat will transfer thru and you can wrap to thickness that feels good...and it comes in wacky colors and styles. I tried some gel padded Olympia gloves yesterday and it made a diff for me
    Steve Henson
    ggfossen
    I found a set of gel pad gloves at Harbor Freight for 12 bucks. They fit well, and have properly installed gel stuff in all the fingers, too. They make the grips fell larger, and seem to help some of my numbing problems. The backs don't provide the protection of the more spendy gloves, by the air seems to flow through, and that's good in the summer.
    I don't remember the name, but they are light natural leather color with black material.
    Gary
    Urbana, IL
    Quote Originally Posted by The_Veg View Post
    The grip starts with a plastic tube which is spiral cut on the surface and wrapped with the heater wire in the spiral cut. Then there is a wrap of sticky paper like material and the grip is slipped over all that. You can carefully cut the grip to almost it's full thickness and pull it apart and off the heated part. Then put any grip you want on it with hair spray or some other slime that will allow slipping it on and then drying sticky. The grips that are solid like on the new K12S and others are much hotter than the ones on the K12RS that had the circular grooves. I always wondered why, maybe the grooves and the air that kept you away from the grip. I like the new solid ones better.
    My other bike is a BMW.
