Results 1 to 10 of 10
Thread: R1150RT Oil Filter Problem
    The last time I changed my oil and again when I changed it today, turning the oil filter was much different than I am used to. With my previous two BMW's and cars I've worked on, the filter turns freely until the gasket contacts the block. On this bike the filter is relatively hard to turn right after the threads catch. There is no way to sense when the gasket contacts. Has anybody else had this experience?
    Frank G.
    Hattiesburg, Mississippi
    2004 R1150RT
    BMWRich58
    Nope. But it sounds like something could be cross threaded.
    WC Indiana
    Bad/wrong filter
    Were you using a BMW oil filter?
    There may be a problem with the threads. The resistance you felt tightening the filter may have been new threads being cut on the filter. I'd pull the filter and check it out.
    I got a spin on filter once with no threads. JON
    Blocking the slow lane
    Edwardsville, IL
    My K1200RS did the same thing, so I sold it and went back to a K75.
    Jon Diaz
    BMW K75/K12GT
    BMWMOA Ambassador
    I also vote for cross-threaded. My RT filter spins on the same as my GS, which is as you would expect...smooth, then you feel it getting tighter when the gasket touches the case.
    Important note: Do be careful not to overtorque the filter. It doesn't take much - 11Nm.
    "No one wants advice -- only corroboration." -John Steinbeck
    Like San Jose BMW Motorcycles on Facebook.
    I think it is OK now. One guy suggested the old gasket from the dealer oil change might be up there. I pulled the filter and looked up from underneath the engine. Everything looked fine. I took the gasket off the new BMW filter and hand screwed it on to check the threads. It turned many times with little resistance. I put the gasket back on and reinstalled the filter. This time it felt normal -- a couple of no resistance turns and then the gasket grounding. I snugged up and started the engine. No leaks. Perhaps the threads were gunked up or the cold fitting was smaller than when it is hot.
    Frank G.
    2004 R1150RT
    What's that noise...? basketcase's Avatar
    Alabama
    My vote (based on experience and my 7th grade science teacher's lesson on metalurgy) goes to the tighter fit when hot.
    So how does the R model oil change compare to sticking your hand upside the crankcase of a K? Quicker or slower, more tedious or easier, etc.?
    '98 BMW Z3 Roadster, '00 R1100RT
    If you insist on exercising a right to burn our flag, first be so kind as to wrap yourself in it and then douse yourself with gasoline just before you strike the match.
    The oilhead is WAY easier and much less messy. That's why I was so upset at problems with the filter.
    Frank G.
    2004 R1150RT
    Focused kbasa's Avatar
    Did you fill the filter before installation, Frank? That's one of the things I like about Kbikes and Oilheads; you can fill the filter before install and have full oil pressure faster.
    Dave Swider
    Marin County, CA
    Yep. I always do that. It makes it a bit of a balancing act as you raise it into position, though.
    Frank G.
    2004 R1150RT
