Results 1 to 7 of 7
Thread: Changed my brake fluid
    On the Road
    Nov 2003
    Escondido, Calif.
    After reading the factory manual that says only "special" equipment available to BMW dealers can be used to change brake fluid for my K1100rs ABS....I became immediately suspicious...having worked on my own cars for many years I knew that the swap of fluid in ABS cars was a non-event.
    To further my knowledge , I called Speigler Brakes and discussed this and was told that the bleeding of ABS was no more difficult than non-ABS except that one must progress in a logical order, ending at the caliper.
    Did my own this weekend and it was a piece of cake...funny how a little investigation can bring nice results....sooooooooooooooo
    a. Saved myself $450...( what the dealer quoted to do this "difficult" job).
    b. Found that my right front caliper that the dealer (Brecht BMW in Escondido, Ca. ) told me two months ago had a leak and "had" to be repaired..had no leak at all....you don't think the dealer was being dishonest do you ?
    Spring Lake NJ, USA
    Re: Changed my brake fluid
    Umm.. Gary?
    What model K bike?
    Spring Lake NJ, USA
    Woops - sorry - didn't read it carefully enough (brain fade)..
    As long as you don't have the new EVO brakes - there is nothing really special about flushing the brakes. A power bleeder makes the job a real no event.. Mine cost $10 to make and makes the job almost a pleasure to do.
    What's that noise...? basketcase's Avatar
    Alabama
    Power bleeder?
    Could you say a bit more?
    My interest is piqued.
    '98 BMW Z3 Roadster, '00 R1100RT
    If you insist on exercising a right to burn our flag, first be so kind as to wrap yourself in it and then douse yourself with gasoline just before you strike the match.
    Spring Lake NJ, USA
    Re: Power bleeder?
    Sure.. not my idea, but a great idea..
    http://www.apexcone.com/JimPowellHom...r/bleeder.html
    All you have to do once you build it is collect spare caps for the brake reservoirs on your bike (or car) and do a bit of plumbing on them.
    I've found most dealers will happily save and give you old caps from master cylinders they've replaced. The old ones don't have a great deal of value :-)
    Total cost of mine was:
    Garden sprayer - $7 at Home Depot
    Tie wraps to secure hoses to cap - no cost, have a bunch
    Plumbing fittings for cap - no cost - have a bunch at work.
    Has the GS-Lust The_Veg's Avatar
    Sep 2003
    Atlanta 'burbs
    Speedbleeders are a good thing too.
    2012 R1200GS
    "If you can't fix it with a hammer, it's electrical." -somebody's dad
    Spring Lake NJ, USA
    Better than nothing - but you still risk the master cylinder by doing hand bleeding (or flushing) by going beyond the normal wear portion of the bore.
    You usually don't know this until some weeks later when the cylinder starts leaking.
    For $10 - why bother?
